Question about Kenmore Elite 45986 Front Load Washer
Spots on clothes
When we wash clothes, sometimes the clothes come out with spots matching the holes in the drums
  • 833 Answers
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Posted on Dec 02, 2008
2 Suggested Answers
fanny
  • 146 Answers
SOURCE: Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
Posted on Oct 31, 2007
Whirlpool front load dryer - gives little holes in the tee shirts and other clothing's. Sometimes it feels like its burnt and sometimes its just holes and ripped
Check for sharp edges and pinch points on the ribs in the drum that tumble the clothes. I had my drum replaced under warranty.
Dec 14, 2016 | Whirlpool Washing Machines
My washing machine although washing and emptying quietly. When it goes into spin and slowly gone very noisy, perhaps like a grating sort of noise, but no strange smell. I have tried spinning slower but it...
maybe a under wire from bras stuck in drum.when machine is empty look in drum holes and see if anything is poking through the holes.keeping turning the drum as you look,sometimes hard too spot has the tips are often white.
Mar 31, 2015 | Ariston Technologies Washing Machines
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
I have a frididaire front load washer, and lately I have been seeing hole like spots on my white or light clothes what is the problem
Check door boot at tub. sometimes is ripped. also check your dryer...at the drum to front panel....felt could be worn and will cause clothes to catch.
Jun 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Continual Spot producing problems Calypso Washer
Check the fit of the agitator to the drum. The closer to the botttom of the drum the better. If the agitator can be moved up to create a gap, find out why.
May 04, 2009 | Kenmore Washing Machines
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
Dark Grease stains on my Kenmore Front Loading washer
THE SEAL IN YOUR TRANSMISSION IS GONE. NEEDS TO BE REPLACED.
Dec 13, 2008 | Washing Machines
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Greesey Spots.........
looks like the grease would be coming from the shaft at the middle of the tub. that would be the only source of grease in that area.you need to remove the whole drum to look at it.
Feb 19, 2008 | Washing Machines
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
335 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
