Question about M&K Sound Mp Series MX-350 MK II THX Subwoofer
M&K series mx200 subwoofer humming
Just started humming over night im guessing a short in the amp, but since they are out of business i cant find a schematic for their amp to check what may be shot.
any suggestions?? thanks, Andy
  • 3 Answers
There are a couple of possibilities. The first one is just moving the ac cord that goes to the power supply away from the board by tucking it into the insulation. The other is you may have a bad (oscillating) STK- 4050 output IC which is availabe from MCM electronics. The power supply caps may also need to be replaced.
Posted on Mar 08, 2009
  • John Mansour-Dumas Sep 09, 2014
    Also, the humming could be caused by the op amps which can be changed to TL064's
I have a yamaha yst sw320 subwoofer connected to a yamaha dsp-a595a amp. I recently disconnected my equipment and when i reconnected it im getting a feedback hum/noise through the sub. I've tried...
Subs don't go to a variety of connections on the amp. Let's stop guessing and stick with the prescribed one.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Yamaha-YST-SW320-Subwoofers-manual/id/320bh340/t/2/
See page E1 regarding placement and safety.
http://www.retrevo.com/support/Yamaha-DSP-A595-Amps-manual/id/319ag821/t/2/
Page 44 - read about "humming".
If you have hum on the sub, is it there with and/or without the input cable attached?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 02, 2011 | Yamaha YST-SW320 Subwoofer
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
60 HZ hum
Rita's Vintage Audio Repair is a Bob Carver Company & can repairs & updates Subs at a reasonable cost try calling them.
May 05, 2009 | Sunfire True Sub MK II Subwoofer
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
Amp turns off or goes to protected mode during long low base
Let me take a stab at it There are two types of resistance... Static and dynamic. These resistance change depending on the position of the cone. Now im guessing the short bursts of bass are not small ones. If the cones are forced further than allowed the resistance of the combinded drivers may drop below the rated impediance for the amp...causing the amp to into protection to keep itself from over driving itself (the less reistance a amp sees the more power it will produce, till it essential blows itself up)
Mar 16, 2007 | Pioneer TS-W256C Car Subwoofer
M&K Sound Mp Series MX-350 MK II THX Subwoofer Logo
986 people viewed this question
Top M&K Sound Mp Series Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a M&K Sound Mp Series Audio Player and Recorder Expert? Answer questions, earn points and help others
