Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
TIMER DOES NOT ADVANCE
Yesterday while running he dishwasher I smelled something burning comming from the doof of the dishwasher. The timer would not cycle ofter that. I replaced the timer $ 108.00 and installed it and it still does not cycle. I am getting 5.6 volts when the power is on and going to the timer. It doesn't see enough. Is there somthing else in the circuit that is preventing the timer from cycling. HELP! Thanks
  • Stewart00100 Dec 04, 2007
    Dear Fix Ya,
    I have had the same problem and the timer has been replaced twice on my now 6 year old Viking Dishwasher. The part is warrantied for 1 year. I ordered a new one and need to replace some of the burnt wires. What is the gauge on the wires? This website has been very helpful. Thank You.
    Sincerely,
    Stewart
Mr. marconi,
it looks like i have the same problem.
at the end of the cycle the machine keeps draining and never finishing.
where can I buy the timer for $108.- ?
thanks for helping.
behmoaras
mmikeb@attglobal.net
Posted on Dec 09, 2007
    Novelist:
  • 116 Answers
At the point where the wiring comes from the bottom of the tank and rises up the door is prone to burning. Before doing the following remove power from your dishwasher. By removing the kickplate at the front and inspacting the bundle of wires you may note that some of the wires are lumpy or burned. These wires need to be repaired. Failing that there is a cycling thermostat mounted to the bottom of the tank above the water valve. These cycling thermos will prevent the timer from advancing there should be a wiring diagram inside of the door that will help your efforts.
Posted on Mar 10, 2007
SOURCE:
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
My GSX4756 dishwasher seemed to stop mid cycle and the start light is flashing. I have pressed the start button until the light goes out but as soon as I close the door it starts again on the rinse cycle...
I think.
However, rarely have I encountered an inlet valve that emitted a burning smell. So I'd expect there to be some other problem in there.
But, if the inlet valve didn't pass the test, then it needs to be replaced. Plus, if it was stuck on the rinse cycle and the valve was out, then that is where the cycle would hang up.
Burning smells usually come from a motor, a belt, shorted wiring or a heating element. So if everything else checks out, then go for replacing the valve. The instructions are included in our dishwasher repair section.
Jun 27, 2008 | Bauknecht Dishwashers
Ge americana dishwasher m#adw1100n10bb is not pumping out water and burning up silenoid to pump can smell silenoid burning
Sometimes the timer on this model will stall out and cause the solenoid to burn up, this unit doesn't have a separate drain pump so the solenoid would be why it isn't draining. It's possible that the new solenoid will take care of it with no other problems but if it burns up again then you may have a bad timer
Jan 28, 2014 | Dishwashers
Washer seems to be stuck on spin. Has slight oil/rubber burning smell. Will only advance out of spin if you manually turn the knob to the next step.
The timer is bad and needs to be replaced. if you continue to run it this way you will need to replace the motor coupling real soon. That is where the burning rubber smell coming from.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jan 20, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter.
Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.
In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem.
For more troubleshooting tips and solutions, see Dishwasher not draining. I hope this helps!
Sep 27, 2012 | Kenmore 665
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Kenmore washer
Im sorry to here the timer replacement didnt help
T
Jul 19, 2008 | Washing Machines
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
427 people viewed this question
Top Viking Dishwashers Experts
Pierre Laplante
Craig Butler
Craig Butler
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
