Question about LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur...
Interior light wont turn off
I have an lg fridge. the interior light wont turn off. i unid the bulbs as the wires were mlting to the top of the fidge and it was warm inside
  • 1 more comment
  • capdm Dec 05, 2008
    awesome job guys. they are coming out today to fix the problem.
  • Anonymous Feb 25, 2009
    It was working when I left in the morning and came back after work and the inside of the fridge was like a oven. The light bulbs had melted the light cover off.
  • maverick987 Mar 28, 2009
    I have the same problem. The lights won't turn off actually melted the top of a milk carton on the top shelf.
    Scholar:
  • 62 Answers
THE PROBLEM IS CAUSED BY A BAD MAIN CONTROL BOARD LOCATED ON THE BACK OF THE REF AND IS COVERED BY A PLATE WITH A BUNCH OF SCRREWS. ALSO, LG HAS EXTENDED THE WAR TO COVER UNITS PURCHASED IN THE LAST 3 YEARS TO CORRECT THIS PROBLEM. CONTACT A LG DEALER OR CALL THE COMPANY TO SEE IF YOU ARE COVERED BY THIS WARRANTTEE REPAIR
Posted on Dec 02, 2008
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
Phillips fidge model 71-357c light for interior
Is there a model number posted in the refrigerator?
Nov 14, 2012 | Refrigerators
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My lights inside my fridge won't turn off. It was fine this afternoon and now it's not. It's not even 3 years old. The heat from the bulbs is making the top 2 shelves too warm and I have already been...
Your Refrigerator light door switch may be broken or damage.
1) Check manually Press the button on hand. Light off or not.
2) Light not off - replace the switch.
3) Light off - Door position or alignment not correct.
Mar 26, 2011 | LG LFX25960ST Stainless Steel French Door...
The light has not been turning off which melted the plastic covering over the light bulbs and its not hanging by a wire and the light still on. the censers on the door do not turn it off anymore i...
Karri,
I experienced the same problem with my LG refrigerator (model LFC25760ST). Came home from a weekend trip only to find that the light bulb assembly had melted and dropped onto the top shelf. The interior of the refirgerator compartment was very warm (est. 70 to 80 degrees) and everything in it had spoiled. Fortunately, nothing worse had happened. (According to consumer information on the Internet this LG refrigerator is suspected - but not proven - to have been the cause of a couple of house fires.)
There was no recall, however, because the reports to the Consumer Products Safety Commission were for less than 5% of this model sold in the U.S. But if you contact LG customer service (1-800-243-0000) whether your unit is still under warranty or not they should send someone out to replace the lamp assembly at no charge to you - this one with a heat sensor that serves as a backup to turning the lights off once the doors are closed.
Newer LG refrigerators have LED lights instead of incandescent light bulbs so they don't produce enough heat to warm the interior of the fridge or melt the light housing.
To learn more about other folk's similar experiences with these LG refrigerators just do an Internet search using "LG and "LCF25760" and "melted plastic." (Note: Leave the other letters after the five numbers in the model number off - they only refer to the exterior finish [i.e., "ST" = stainless steel] and unnecessarily narrow the search so as to miss some links.
Good luck with LG customer service.
grm
Feb 15, 2011 | LG LRFD25850 French Door Refrigerator
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Dec 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Lights staying on
You need to replace the door switch, as it is allowing the interior light to stay on, but also it's keeping the fridge section circulating fan from coming on, and that is what is really causing the interior to heat up.
It's located in the top hinge plate cover and you can test for faulty operation by removing the switch and connecting or disconnecting the wires together to see if your light goes out and the circulating fan starts to run. If so, the switch needs to be replaced.
The part number is #6600JB3007K and costs about $8.00. You can order it from several online sellers or at www.searspartsdirect.com
Here's a diagram of your fridge and the parts list with pricing.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=LFX21971ST&productCategoryId=0161000&brandId=3204&modelName=BOTTOM-MOUNT-REFRIGERATOR&diagramPageId=00001&componentDescription=CASE%20PARTS&documentId=F0902046&backToLink=Return%20to%20Sub%20Components%20list
Hope you found this very helpful and best regards!
Aug 07, 2009 | LG LFX21971ST Stainless Steel Bottom...
LG Design defect - Light stayed on and melted the fridge.
yes, contact LG for this known problem. it's a circuit board defect. the tech should replace both bulbs w/lower wattage, plastic bulb lens, lens surround and bulb sockets themselves. be sure to have your fridge model # and serial # handy.
Jul 12, 2009 | LG LFC25760 French Door Refrigerator
LG LRFD22850ST French Door 22.4 Cu. Ft. Refrigerator w/ Multi-Air Flow & Digital Read Out Temperatur... Logo
291 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
