Configuration code required for used d-link wifi router
    Scholar:
  • 118 Answers
Open web interface of your wireless router (address will be given in its booklet)
Find the security option. and provide a WEP key there..
and save the setings.
next time it will ask you for the code to connect.
regards,
Posted on Dec 02, 2008
No wifi available device missing
You own the router? Have you know its configuration? Can you log on the device pluged in by wire?
Run the software setup that comes with the device and go through all the configuration parameters, then disconnect and verify WIFI is turned on on your computer. Copy the information (encryption Key) using a USB pendrive from the information in the router configuration *you did save this?) to the key required to connect by wireless... it will ask for it!
Sep 12, 2011 | Computers & Internet
I want to use my wifi router D-link dir-600 for internet wifi. After I set everything according to manual guide, I can detect the wifi signal, eventhough I have enable the wifi in the router.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router. For Internet access you need to connect your DSL or cable modem to the WAN/Internet port on the D-Link.
Apr 08, 2011 | D-Link DIR-600 Router
The WiFi light is flashing. I couldn't log on internet via. the router. Much appreciated in advance, ZL
properly configuring the router?
check if the WAN port configurations are required by your ISP.
Feb 20, 2011 | D-Link DIR-615 Wireless Router
I am trying to download and install drivers for my dlink dir 615 router but i cannot seem to find them. and install them. HELP??
You can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 11, 2010 | D-Link Computers & Internet
I am not able to understand how to use the wi-fi in my samsung corby pro mobile
you need to understand two things.
Wifi is a service which requires an access point i.e. a Access point hardware, also known as Wifi Router and A wifi enabled phone. As you hve mentioned that you have corby- pro, it does have a wifi chip to access the wifi signal. Now you must get a wifi access point, i.e. a Wifi router, d link has veriety of routers, Now connect the router with broadband internet line and enable it. Configure the router through your desktop.
Now switch on the wifi on the corby pro and establish connection between the wifi router and corby . Then only you will be able to connect with internet..
Dec 01, 2010 | Cell Phones
I brought new wireless router G ADSL2 4 PORT ROUTER but i dont know how to fix
Configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Not able to configure wifi router
im having trouble with wireless connection it says i have full signal but is not connected
Feb 13, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
I am not able creat Lan computer with D-Link Dir-300 wireless G router. We require lan for 4 Computers. One node is working with Wire less and other with cables. Previously I used D. Link Router
connect your wireless router with swithch with straight cabvle of lan. bt first connect your wifi router with any computerr so u can configure it as dhcp enabled.
Jan 03, 2009 | D-Link DES-3052P 48-Port 10/100 Managed...
Everything is working very well on my di524
To my knowledge, the only password that could be set/changed is when you log into to your DI524 web configuration page. Once the WiFi router is setup and running, you can also changed. There is no password required for your wireless clients (users). There is however a provision for Security key which could be WEP, WPA or WPA-PSK. All of these could be accessed upon entry to the web configuration page of the DLink DI-524.
This page is an emulator that can help you be familiar how things are done to configure your WiFi router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 15, 2008 | D-Link AirPlus DI-524 Wireless Router
New HP laptop wireless connection to BT1800HG router
Hi, Have you tried inputting the necessary security code to your HP laptop? Most if not all BT1800HG wireless router modem comes pre-configured to use a certain WEP code. In your HP laptop go through the WiFi configuration/Setup. Select option to use WEP security, type in required code normally found on the bottom of the BT1800HG. The numbers and/or characters below the bar code is the WEP code. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
