Question about Drills
Drill bit is stuck inside my makita drill chuck
The drill bit is stuck inside the chuck. it went in smooth and when i went to reverse the get the bit out of there it wont budge.
  • philphixit Dec 26, 2008
    I have a RIGID right angle impact driver that came with a Makita keyless chuck. I can't remove a drill bit that I used. (12v)
  • Allen Neal
    Allen Neal May 11, 2010
    keyless chuck or other
    Problem Solver:
  • 9 Answers
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
Makita HR3000C. drill bit stuck in chuck
Here is a breakdown. https://www.ereplacementparts.com/makita-hr3000c-rotary-hammer-parts-c-97_380_507.html Here is the page of the manual that deals with bits http://powertool.manualsonline.com/manuals/mfg/makita/hr3000c_2.html?p=7
Aug 08, 2017 | Makita Drills
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
I have a 18 volt makita cordless impact driver i can not get the driver bit out it seems to be stuck in the chuck very tight
Try holding the bit with pliers and running in reverse, maybe with a shot of oil. That might free it up. You can also try tapping it (firmly) on the side of the bit
Aug 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
Keyless chuck is stuck with bit inside I can't turn it counter clockwise to unlock I have a Makita 6349d drill
Try two channel lock pliers.
Hold the bit close the the base with one.
Take the other (cloth comes in handy here to prevent marring) and turn the chuck counter clockwise to release.
Alternative (little WD40 on the chuck)
One channel lock plier hold the chuck and put the drill in reverse.
The WD40 should allow the chuck to release easier.
Nov 10, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
1,548 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
