Question about Indesit WA 125 Front Load Washer
Change grip/handle on a indesit washing machine w105tx
Hi!
I need to change the grip(handle/hold of a indesit machine w105tx. How do I do this?
Thanks in advance
  • kri_lle Dec 03, 2008
    Thank you for taking time with this issue!
    After I've removed the cover, I fear the handle and the lock will fall apart and that it will be difficult to get it fixed again.
    Are there any certain issues our ruls of thumb that I should think of before I undo the screws and put the hatchet into two halves?
  • Indesit Master
  • 3,463 Answers
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Posted on Dec 02, 2008
  • Barry Coates
    Barry Coates Dec 04, 2008
    Normally the door handle assy remains intact, take particular note where all the parts are fixed, and make a diagram of how it looks befor you tak it apart.
    That way you should have no trouble.
    Good luck.
SOURCE:
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Hi, How to remove the Centre spindle screw in Indesit washing mac
I think its anti clock to remove however it will have loctite on it ..Try heating the screw 1st this will break down glue, carefull not to burn surrounding area
Mar 31, 2010 | Indesit W 123 Front Load Washer
Hi there where can i download an operation manual for an Indesit WIL103 washing machine thanks
Hi
In your browser bar type in---- indesit user manuals
In the drop down list click on------indesit- manuals-user guides-handbooks-indesit service
In the search box type in your model number, and down load instructions.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Washing Machines
Diplomat apm8703 heater element gone
The nut should taken off completely, and then lever the heater out with a broad blade screwdriver or similar, u need to get behind the metal plate that holds the heater in, or get a good pair of grips and grip the metal plate of the heater, and pull it towards u,it can take some doing as the rubber seal will have expanded, and that is what is holding it in
Plz rate my solution and feel free to leave a comment.
Thanks.
Jan 01, 2009 | Indesit W 123 Front Load Washer
Indesit wil 143 washing machine
It is automatic half load you dont need to do anything.
Oct 04, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine wd10uk
Hi, you will have to remove the door seal fastener first, the just push the door seal inside the drum.
Mar 30, 2008 | Indesit WA 115 Front Load Washer
Indesit WA 125 Front Load Washer Logo
453 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
