Question about Roland Music
Keys don't work in random pattern formation
Counting the keys from left to right, from switch on every third key won't work, run your finger up and down the keyboard and then three keys don't work out of every five, press lots of keys randomly and the left to right pattern is working, not not, working working working, not not, working, not not, working working working, not not, various numerical patterns of keys not working. The three tranistors on a heatsink in the power supply were all dry joints but soldering them didn't help.
  • Generic problem for all Roland Musical Instruments
    var g_tryMail = 0;
    function addthschng()
    if($i('at_email') != null)
    addthis_sendto('email');
    else
    g_tryMail++;
    if(g_tryMail
    Report abuse
    posted by djfixit on Dec 02, 2008
  • Roland Master
  • 5,603 Answers
The keys are scanned in a matrix. It sounds like two of the matrix lines are broken. They may be broken on the board which the keys contact. These are often conductive rubber "pills" pressed onto finger like patterns of circuit traces. The traces have a black coating in the contact area. If the keys have been "mashed", sometimes the board is cracked. IF the crack goes through one of these contact areas, that is fatal. That board needs to be replaced.
A loose cable where two wires of the matrix aren't contacting would do it as well.
Posted on Jul 29, 2009
What are all the left side controls on an Elegance JC-618 electronic keyboard
Single and Finger,is chords mode.
In Single,by press one key (eg:A) then chords A is heard,and so on.
In Finger,you must press 3 keys.Example: G-B-D,then you heard G chord. D-F#-A is D chord.
In Finger,lets say you press A chord and want to change to C chord by press one key C only,there's nothing change untill you press C-E-G.
Low, is for chords octave low.
Chords Off,no chords can be play,it mean overall full piano mode..
Single,Finger,Low, can be activate with Sync Start button.
Aug 17, 2015 | Music
I have three keys getting malfunctioned /cords not changing in left side, on split board.can this be fixed?
If those keys work normally, it's hard to see how the key switches themselves can be bad.
Is your keyboard MIDI capable? If you play the same chords, does the MIDI output look OK?
Could it be that your keyboard simply can't play all of the different sounds at the same time? I know some are limited in how many simultaneous tones can be played.
Jun 09, 2015 | Music
Yamaha pf85 14 keys not working & two of the three circuit boards look damaged.
The PF-85 action works by having the hammers strike the contact strip, which in turn connects the trace patterns on the circuit boards you're looking at together.
Any dirt between the contact strip and the circuit board will cause the keys to not function correctly. You can remove dirt with rubbing alcohol (iso-propanol) and a cotton swab. The only thing on these boards is traces, contacts, and diodes so they are safe to handle...just don't get finger prints on the contacts.
You should also make sure that the white wires are plugged in all the way on the back of these boards. A loose connection will cause the problem you've described. As would missing screws!
Sep 13, 2012 | Yamaha P-85 Electronic Piano
Some key in my xp-50 doesn't work,same as midi signal? Rich
Since you haven't told us much information, I can only suggest you check the TRANSPOSE settings. These cause the keys to shift left or right INCLUDING the black keys.
Aug 05, 2011 | Music
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
Just purchased, certain keys produce no sound
Are the silent keys random or in a pattern (e.g. a group of adjacent notes, every B and G or just all over the place)?
Unless you have got a keyboard split in operation (dividing the keyboard into two separate sections so that you can have a different 'voice' in each part) and have failed to allocate a 'voice' to one of them you have to suspect either a faulty keyboard module or a faulty processor.
If you bought it from new take it back under warranty. Otherwise it will be a job for a qualified engineer with the appropriate test equipment.
Feb 10, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Wisdom required
If you can find the C-below-middle-C ?
Put your small finger on C,
your next finger on the next white key: D,
your middle finger on the next white key: E
your index finger on the next white key: F
your thumb on the next white key: G
Lift your fingers away from D and F -- to keep this simple -- all we did was identify the D and E and F and G keys, relative to the C key.
Press C and E and G (small, middle, thumb)
to play a "major" chord in C.
Move your fingers "up":
C to D, E to F-sharp, G to A,
and play a "major" chord in D.
D to D-sharp, F-sharp to G, and A to A-sharp,
and play the chord in D-sharp (usually called 'E-flat').
D-sharp to F, G to A, and A-sharp to C,
and play the chord in F.
Move your fingers "up",
F to G, A to B, and C to D,
and play the chord in G.
Go back to the starting position (C-E-G),
and move "down": C to B-flat, E to D, and G to F,
and play the chord in B-flat.
So far, you have C-major, D-major, E-flat-major, F-major, G-major, and B-flat-major.
There are more chords, but most pop-music is in one of these keys.
Give it a try.
A lot of left-hand stuff is just the small-finger and thumb, omitting the middle finger, e.g., C&G,
to avoid a too "muddy" sound.
Or, "stretch" your hand: C-and-G-and-the-next-higher-C.
Jan 14, 2010 | Yamaha Full-Size Keyboard
Yamaha electronic piano keying circuit broken
The interdigitated fingers are circuit traces coated with a very hard, non wearing, carbonized type conductive surface. If a board crack runs through this carbonized area, that is FATAL. Replace the circuit board.
Realize that these contacts drive high impedance CMOS circuitry so the contact resistance is often in the 200 to 1000 ohm range.
The silicone rubber domes contain a conductive rubber pills, often two of them. One contacts the fingers before the second and the time difference between those is the measure of "velocity".The silicone dome acts as the restoring force for the key.
The keyboard is scanned as a matrix. Strobe lines intermittently select the first and then the second of the finger patterns, ONE octave at a time. The octave, 12 notes worth, are read in parallel one at a time.
The diodes are "disconnect diodes" which preven sneak paths when more than one note is held that are in different octaves.
Nov 17, 2009 | Yamaha Music
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
540 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
