Question about GE (PSS26MSRSS) Side by Side Refrigerator
TOO MUCH ICE
MY SIDE BY SIDE GE FRIDGE HAS A CLOGGED DRAIN.
I WAS TOLD THE DRAIN IS IN THE FREEZER AT THE BOTTOM, BUT TO GET TO IT IS NOT POSSIBLE AS THERE IS TOO MUCH ICE ACCUMULATED. WHATCAN BE DONE TO RESOLVE THIS ISSUE.
PLS ALSO CONFIRM IF THE SIDE BY SIDE GE PROFILE REFERIGERATOR HAS THE DRAIN PIPE LOCATED IN THE BOTTOM IN THE FREEZER. THKS
    President:
  • 1,462 Answers
Just switch off and melt the ice away with a hairdryer.
drain is behind the back panel inside the freezer
Posted on Dec 03, 2008
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Ge side by side model tfx27pfx. Ice maker not
Your defrost drain hole is clogged. Turn the fridge off. Defrost the drain hole in the freezer. You will be fine until it does it again.
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE TOP Freezer Model # TBX21JABLRBB
Turn off the fridge. Remove the rear freezer panel inside the freezer. Take a hair dryer and thaw the ice in the drain trough at the rear of the freezer. After it is clear, pour a 1/4 cup of bleach into the drain hole. Adjust the front leveling legs on the fridge to make the fridge tilt slightly to the rear.
Jul 06, 2009 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Nov 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Water leaking from bottom
my GE side by side fridge leaks water from the bottom only when I connet the water filter inside the fridge. The leak stops when I remove the water filter. What could be causing this?
Jul 14, 2008 | Refrigerators
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
175 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
