Ecoquest Fresh Air Living Air Purifier
Problem for Ecoquest Fresh Air Living Air Purifier
Ecoquest Freshair unit; fan is intermittent.
By susanszy on Dec 02, 2008
My Ecoquest Freshair unit, about 2 years old and well-maintained, has developed a mysterious habit. The fan, which seems to work just fine, will suddenly stop for a second then resume. The unit is very clean, the filter looks good. Any ideas about what may be causing this, or has anyone else experienced it?
Thank you!
Susan
Same Problem
Mar 14, 2009
-   My unit is "cutting" out intermittently - the entire unit quits then restarts. I haven't been using it because I was concerned it may start a fire.
Also has anyone had any health problems they feel are related to the use of this machine? It is difficult to tell truth from hype from bad info.
Thanks L-   m_lee_mck3
Dec 09, 2008
-   fan was decreasing in air flow. After cleaning, still wasn't improved & became intermittent. Now doesn't work at all. It all started with the fan.-   JeriLucas777
Solution #1
posted on Feb 06, 2009
Not Rated)
Dutch7773
Rank: Wiz
Rating: 84%, 15 votes
Hi Susan,
I have not experienced it but I know that if you bought your FreshAir from a dealer with EcoQuest you are entitled to a 3 year warranty.
Contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
If you are not in contact with your EcoQuest dealer anymore and the unit has never been registered with the company you need a purchase receipt with the date on it.
Hope this helps!
Eric
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Living Air
Questions and Unsolved Problems for Ecoquest Fresh Air Living Air
Do you recommend Ecoquest Fresh Air Living Air Purifier?
Answer
Answer
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several... (More)
Answer
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine... (More)
Answer
my eco quest fresh air turns on and off continuously
Answer
I have two identical units and I have swapped every removeable/replaceable part including cord and... (More)
Answer
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Fresh Air Living Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2536
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
