Question about Sony KV-32S45 32" TV
Picture Flashes off and on
9 year old KV-32S45. The picture w/sound has begun to flash off and on when the TV is turned on. Does it on all inputs (line and tv). Picture with sound only, the set power is still turned on. At first it would last a minute or so then stop. It now flashes off and on for over 5 minutes and the flashing is fairly rapid at first, then slows in pace as the set warms. It will then stop for a period, 10 minutes?, and then do it again for a few times before taking another rest from flashing. The picture quality appears to me to be perfect. bright and vivid colors. Just won't hold on. A slight clicking sound goes with the cycling of the picture. Is this a old picture tube going? Worth getting even it looked at? Thanks!
It was the Screen control as I know understand these to be 99.995 of the time (Sorry to say in the first post that sound was on..it wasn't). Turned up the control, easy to get to...just rememeber to unscrew ALL the screws and not yank out the board and it's attached ribbon cables as you remove the back. Problem fixed for a short period (months?) as I understand. Sooner or later the tube gives out and you can't keep upping the power to offset. At that point it is plasma vs. LCD. And to think a TV tech would have wanted $125 for a 15 minute screw allright..LOL Somethings better to do yourself.
Posted on Mar 21, 2007
    President:
  • 3,130 Answers
Try first to turn down the screen control on the high voltage transformer. If that does not work the picture tube is most likely going bad. Sorry to be the bearer of sad news. Good Luck
Posted on Mar 18, 2007
    Problem Solver:
  • 13 Answers
I am having the same problem. I took my set apart and cleaned it out real good and the problem seemed to get better. Now it only flashes for about 10-15 seconds and then stops. I am going to search for loose solder points in the next day or two. Hope it works!!! I'll let you know if it does!!
    Scholar:
  • 168 Answers
Probably the tv has a loose solder in the board. this is normal especially when tv is aging. most of the components inside are emitting heat resulting to loose the solder. try to inspect and resolder if possible. but if you dont have the proper tools and equipment and you're not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Posted on Feb 07, 2007
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Aug 25, 2009 | Sony KV-32S45 32" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Kv-35s42
HI
Don't beat it with a bat LOL, the problem your having is a simple solution, however this would be best left to a qualified tech to do, the Screen Voltage needs to be tweaked up just a tick, I've worked on alot of these sony's and 9 times out of ten thats what it is.
Mark
Nov 28, 2007 | Sony KV-32S45 32" TV
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Sony KV-32S45 32" TV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
