Question about Samsung Lands Phones
When i press the ringer button on the side, or the # buttons 2 5 8 or 0 on my sph-a660 phone, the phone starts ringing or vibrating or just repeating any combination of those numbers and changing the ringer volume. all other buttons work, and phone can call out, just can't use those buttons without strange things happening. anyone know why?
Buy a different phone and read reviews on CNET where you would've seen this http://reviews.cnet.com/cell-phones/samsung-sph-a660-sprint/4505-6454_7-30732916.html?tag=mncol;lst
This was a base model when it was put into production and so Sprint never had any intent of investing in things like quality control as some of these phones work perfectly fine and other have tons of problem
Posted on Jan 03, 2009
I have an uniden exa 2980 and losy manual,how do I obtain a copy.also how do I turn up ring volumn?
Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
Feb 12, 2018 | Uniden Lands Phones
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
I dont know how to take off my silent mode
hi justin,
you may wanna visit this link for reference:
http://www.samsungtelecom.com/PDF/A460.pdf
to change the ringer volume from the main menu:
1.press menu for menu options
2.press 8 for sounds
3.press 1 for ringer volume
4.press 1 fro calls
5.select off/vibrate/1-beep/level1-8/ring+vib,and press ok
Apr 14, 2011 | Samsung SPH-a460
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
The ringer doesn't ring, only vibrates. I select "settings" but there is not ringer volume level so I can hear the phone actually "ring', it only vibrates
First, make sure your Jitterbug is open and confirm it's on.
Next, Press the volume button on the outside of the phone below the Outside Display. Press the top of the button to increase the volume and the bottom of the button to decrease the volume.
There are several ringer options available to choose from. If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 and they will walk you step by step through the process.
Dec 27, 2010 | One Touch Jitterbug One-Touch Cellular...
Where is the ringer button on my cordless phone
The phone must have a ringer ON/OFF switch. ... the phone begins to make the ringing sound, repeatedly press the Volume Down button until "RINGER VOL: OFF" is displayed
Jun 25, 2010 | GE 25952EE1 Cordless Phone
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
SOMEHOW MY PHONE RINGER IS OFF, SAIS "SILENT MODE". nOwhere in settings do i see silent mode. It is set for , high vibrate/ring. I pushed one button last night while sleeping, don't know what I did, but...
go to settings -> sounds-> volume-> advanced and then scroll down and make sure all of them say "use ringer volume"...if all of them do, then did you try the volume buttons on the side?
Feb 25, 2009 | Samsung UpStage SPH-m620 Cellular Phone
How do i turn off silent mode? and how did it turn on to begin with
Ok, hold the * button and or # button. This will take it off silent mode, and the reason why it turned on is because someone had to hold the button. So try not to hold it.
Dec 24, 2008 | Samsung UpStage SPH-m620 Cellular Phone
SAMSUNG SPH-M540 MOBILE PHONE
Unlock the phone first then hold down the Star button.. it worked for mine :) hope it works for you
Dec 18, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Lands Phones Logo
127 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
