Question about Husqvarna Freesia 425
I turned the wheel to lower the feeddog on my Husqvarna Freesia and now I can't turn the wheel to raise it back up. What do I do now?
    Problem Solver:
  • 8 Answers
You have to clean the thread out of the place were the bobbin goes
Posted on Dec 02, 2008
  • Lee Montoya Dec 05, 2008
    & u might have to turn the machine on
Machine will not move material under pressure foot. Thread get all bound up like tension my be too tight!
is stitch length setting correct, should be 2.5 for straight stitch. are feed dogs lowered for some reason? raise pressure foot and manually turn flywheel towards you while watching feed dogs. do they move up backwards and down? sounds like they are not feeding fabric through. check manual for how to raise and lower feeddogs if they appear to be down. sometimes its a button on base front or back of freearm. hope this helps out a little
Jun 06, 2011 | Sewing Machines
Settings for stippling freesia 425
Lower feed dogs. Turn on Needle Down. Presser foot pressure on Darning setting. Don't forget to lower the presser foot lever. That's about it! Since you are going to be the feed dogs, it doesn't really matter if you have a stitch length set or not, but do have width set for "0". The spring loaded darning/embroidery/quilting foot is the best for stippling, but try it with any open toe foot you may have. Do a few samples first using the threads you intend using on your project because the tensions might need tweaking. Try to get the result you like by adjusting only the top thread tension. If you really have to adjust the bobbin too, put a small mark on the bobbin case where the "normal" position of the screw is so you can return to that when you are done quilting.
Jan 31, 2010 | Husqvarna Freesia 425
Machine sewing backwards only
If you machine was recently serviced, the service tech might have reversed the motor connections. If not, it could be the zero feeding mechanism is stuck. Try dropping your feeddogs, i.e. like sewing on a button. Then raise your feeddogs to see if the problem clears. What happens when you sew a buttonhole using the automated buttonhole accessory? If these do not work, it may be your pc board which has a 5 year warranty if you are the original purchaser from an authorized Husqvarna Viking dealer. If resetting feeddogs does not clear the problem, Will probably need service by an authorized Husqvarna Viking dealer. If the service tech cannot repair, they can send to Husqvarna Viking Service Technician for repair. Visit the Husqvarna Viking website for a list of dealers closest to you. http://www.husqvarnaviking.com/us Good luck.
Sep 23, 2009 | Husqvarna Viking 1
Bernina Activa 131: Feed Dogs won't come back up
Raise feeddogs with switch, then turn handwheel one full revolution to re-engage the gear......unless something is jammed, that should do it. Do you have your manual ?
Nov 30, 2008 | Janome Memory Craft 9000 Computerized...
Fabric stuck when sewing
Several things could be happening. It may be the hook/needle timing. Or it could be the feeddogs are not moving (that's the toothy looking part under the presser foot that moves the fabric). Recommend removing thread and bobbin (needle and presser foot). Slowly move the handwheel and put your finger on top of the feeddogs to determine if they are moving back and forth and are high enough to move the fabric. Check to make sure you had not manually lowered the feed dogs. You may need to take it to an authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Nov 21, 2008 | Husqvarna Viking 1
Husqvarna Freesia 415 parts diagram
I don't know how much help this will be for you, but here are the parts of the upper shaft.
Aug 19, 2008 | Husqvarna Freesia 415
Husqvarna Viking Designer I (feed dogs will not lower)
Its likely this machines feedogs have either never been lowered or not lowered for a long time. Thus the old oil has hardend and is causing the mechanism to freeze up. A tech would take the bottom cover off, follow the connections from the lowering knob, button or switch to the feeddogs and putting a bit of oil or penetrant on each moving connection. Don't force anything, gently tap where you beleive its sticking and turn, push or flip the switch, knob or button slowly bit by bit, back and forth until they drop. They will work loose then make sure they get a bit of oil again. Hope this helps. Good luck.
Jul 13, 2008 | Husqvarna Designer I
How to raise feed dogs?
Remove the needleplate and clear out any lint or felt deposits from between the teeth of the feeddogs, give the entire bobbin case area a good clean if it needs it too !!.
If that did not solve the troubles, there is a switch to raise/lower feeddogs, once reset to up position, one full revolution of the handwheel is needed for them to engage and raise.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
