Question about Canon Office Equipment & Supplies
ImageRunner Model C2050, error code E020-04A0
ERROR CODE e000001-0008
The fixing film assembly needs replaced.
Apr 27, 2015 | Canon for IMAGERUNNER C2020 C2050 C2058...
What do I do when my printer gives me a error code of e748-2024?
recommended main board 1reseat everything on the boards and the connection between the two there is a comms problem between Cont 1 & Cont 2
Sep 01, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Error code e000020-0250
most likely the cyan drum unit is bad.
Jun 23, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
E000002-0006 error code in c2020
Thats a fuser problem. Check Yours fuser unit if you have a complete set replace the faulty one and have it checked.
Apr 22, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
What is error code e000002-0006
It's a heat rod error code. It can be reset but will come right back untill the problem is fixed.press additional functions, 2 and 8 together, then additional functions again. on touch screen press copier>function>clear>err>ok. if the machine starts up ok, go to additional functions>common settings>energy consumption in sleep mode and set it to high. if it doesn't code again after this the fixing film unit will be ok, if not, replace it.
Mar 17, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Kindly give me the solution for canon C2020L error code E000002-0006
Detection of abnormal temperature increase in the fixing assembly.
Most of the time just change the fixing assembly. part # FM4-6227-000
Dec 20, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon color imagerunner C2050 has a code Eo70-0001 what should I do
Check the home position sensor on the transfer belt. Make sure its not dirty. Also I think there may be some aluminum tape on the edge of the belt for the home position sensor to see, make sure its still there and did get ripped off. I did't actually work on this machine but these are the usual problems on other models.
Oct 09, 2012 | Canon for IMAGERUNNER C2020 C2050 C2058...
My canon color image runner c2050 is giving me a code E070-0001 and need to know what to do about it.
The error means that there is a problem with the transfer belt unit. You may need to replaces the transfer belt unit. You may need a service person to resolve your issue.
130 people viewed this question
old marine
old marine
