Question about Oster 5838 ExpressBake Bread Maker
The paddle is stuck in the pan of my Oster 5838 Breadmachine
The machine was given to me and came with the blade stuck in the pan. How do I get it out so I can use it?
5 Suggested Answers
yalmer
  • 552 Answers
SOURCE: I need to fix the rool of the pan Oster 5838 Bread machine
http://minneapolis.craigslist.org/hsh/574471930.html
Try this link, ther is a bread maker for sale used exellent shape.
Also try www.oster.com and contact customer service.
Posted on Feb 15, 2008
SOURCE: Oster 5838 breadmaker
Yes. I have tried several mixes & all have come out just great. The box usually has instructions on the order to put your ingredients in (so follow that). Yeast first, then mix, then liquids on top. I've even set mine up for delayed baking & they came out well too. Good luck!
Posted on Feb 02, 2009
SOURCE: My new Oster 5838 breadmachine:
twist and pull hard!
Posted on Jan 03, 2010
The agitator turns very hard - like it is stuck partially siezed. Model 5838
Hi..The sealed bearing that the paddle shaft rotates on is starting to fail. Soon it will freeze up entirely and you will need a new bread pan. Fill the bread pan half way up with hot water a few times and see if you can free it up to "buy some time" Hank
Dec 05, 2010 | Oster 5838 ExpressBake Bread Maker
How do I remove the stirring paddle to replace it with a new one? I've tried pulling it out with a large pair of pliers
I'm sorry you used pliers. If it has the non-stick coating you may have damaged it.
I have posted a video on you tube of how to remove a severely stuck bread machine paddle.
Just go to you tube and type in ...How to remove a stuck bread machine paddle or kneading blade"
and you will see how to do it without damaging your paddle or pan.
Nov 20, 2010 | Oster 5838 ExpressBake Bread Maker
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
The mixer blade won't mix. The motor runs but blade won't go.
Take the pan out of the machine with the paddle attached and see if you can spin the paddle freely by hand. If you can that's great. If you can't then the paddle is stuck or the bearing is broken.
Then, with the pan out of the machine start it up and look through the lid . Check to see if the shaft where the bread pan and paddle usually goes is spinning. If not then check to see if the drive belt inside the machine fell off or if it needs to be replaced.
Hank
Sep 14, 2009 | Oster Kitchen Appliances - Others
My new Oster 5838 breadmachine: The bread pan will not come out.
you have to twist the handle a little and oull hard! it will come out, good luck
Dec 13, 2008 | Oster 5838 ExpressBake Bread Maker
Oster breadmaker model 5814
I just bought a pan and paddle from ebay and I do not need the pan. I can see it to you if you like.
Mar 04, 2008 | Oster 5838 ExpressBake Bread Maker
Feb 21, 2008 | Oster 5838 ExpressBake Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
123 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
