I am trying to forward ports on my 2wire router. The only problem is that it will not let me reset my router's password, as the one printed on the label is not working. I have tried to reset the router to the default factory settings and the label password has still not worked.
Are you sure you reset it ? Try holding the reset switch with power off and unplugged for a few seconds, then try resetting with power on.
If after your hint is shown to you, you still can't remember your
password, there is a "I still can't remember my password" link that you
can click to take you to a page to obtain a temporary password. To
obtain a temporary password, you must call the support telephone number
on the screen and provide the special code number that is generated by
your HomePortal. The support representative will use this special code
number to generate a temporary password. Once you have entered the
temporary password, you can then change your password and enter an
appropriate hint.
SOURCE: Hi, I am trying to reset my 2wire 1800HG router in
you have to open internet explorer and type 192.168.1.254. then go to broadband link at the top of the page. hit the advanced settings then you have to re enter all you information like your username, password etc... i hope the helps you if i doesnt let me know.
Open your "Start" menu and go to the "All Programs" section. Open the Command Prompt program in your "Accessories" menu.
Type "ipconfig" in the Command Prompt and press the "Enter" key. Make note of the default gateway address that is displayed here.
Open Internet Explorer and type the default gateway in the address bar to load the 2Wire router's interface.
Click on the "System Password" link if you do not know your password for the 2Wire router. You will be asked to reset it with the system key printed on the router. Or call 2Wire support to get a temporary password.
Navigate to the "Broadband Link" icon to edit the authentication settings used to connect to the Internet. Use the "Home Network" icon to get to the wireless settings. Click on the "Firewall" icon for settings such as port forwarding.
