Question about Rimage Office Equipment & Supplies
Error positioning the re-transfer heat roller.
You want to charge me to get an answer for my problem, but you want me to give you my solution for free?
Think again!
Take me off your mailing list please.
Posted on Dec 03, 2008
I have a problem about transfer belt error 14
Error 14 is actually the transfer roller, error 16 is the transfer belt.
Error 14 is a transfer roller error and roller needs to be replaced. The part number is 059E05450 and can be ordered below:
http://www.iteminconline.com/059e05450_059e05450-xerox-6120-transfer-roller.htm
Jul 30, 2015 | Xerox Phaser 6120N Printer
E000079-0001
The E079 error code indicates the home position of the outside heating roller (engagement) home position sensor does not get detected. The outside heating roller (engagement) home position sensor does not go off.
The detail code 0001 indicates the home position sensor does not go on within 5 seconds after the start of the home position search.
The error code does not reset after the machine's power is turned off and on again.
Check the position of the outside heating roller home position sensor's (PS22) flag. The flag can easily be moved out of position or broken during transport.
Note: the parts manual refers to the outside heating roller home position sensor as PS66 rather than PS22. (See figure 810 page 2-156)
Apr 28, 2012 | Canon imageRUNNER C5800 Copier
E0067-0110
E067 High voltage-related error
0100 The measured current of the primary
transfer ATVC is abnormal twice in
succession.
Check on the primary transfer roller spring, Clean
the position where the primary transfer roller
contacts, Replace the primary transfer roller,
Replace the drum unit Check a value
of COPIER> DISPLAY> MISC> DRM-LIFE, and
replace the drum unit if the value is near 100
because the drum may have reached its life
expectancy.
0110 The measured voltage of the primary
succession.
Turn OFF and back ON the main power
Jun 07, 2010 | Canon iRC3100 Printer
Need Help! What does the Error message "Set transfer roller" mean?
"Set transfer roller" means that the set transfer roller is missing or not installed properly. Install or reseat the transfer roller.
Mar 30, 2010 | Lexmark C500n Laser Printer
Busy, try later error won't go away
depending what rollers and how you did it, you probably have 'spun' a clutch out of position so it can't find it's 'home" position, and keeps on trying. If it worked before cleaning and now it doesn't you've definitely broken or dislodged something like that.
May 25, 2009 | HP 1020 Plain Paper Thermal transfer Fax
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Gestetner 3225
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
314 people viewed this question
Top Rimage Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
