Question about Dell Dimension 4700 PC Desktop
Long time starting
When my computer boots up I sometimes get just a cursor but the main problem upon starting is when the computer gets to the theme and stays that way for a few minutes till the icons appears and finally starts the internet session.
  • 40 Answers
This happens with older machines you are experiencing 2 problems. Problem one you need more ram. the reason you need more ram is that you have too many programs and services starting at once.  I assume you are running windows xp. These dells shipped whith just enough memory to run the os and a few select programs. We are end users installing our own stuff like itunes, games, new printers, IM and others.
Restart the computer.  let it boot up. click start>mycomputer>right click on my computer Click on the properties menu now click the advanced tab Click >Performance settings Now click best performance. click apply ok restart your computer is it faster? even marginally.. if so it is a ram issue. How many icons load up to the left of the clock more than 5 is an issue. that cna be addressed with msconfig..
If you have questions repyl back,
Do not forget to rate me :)
PJ
Posted on Dec 02, 2008
  • 67 Answers
It sounds like you have too many things running at start up or there is a virus on your machine.
I would suggest a virus scan and downloading and installing a copy of SpyBot. If you don't have a virus scanner, you can install Avast! for free and run it.
If you already have one, update the software FIRST, then run the scan.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
When I try to enter to my computer, this error appears: "The procedure entry point draw theme textEx could not be located in the dynamic link library Uxtheme.dll." I'm using Win 7.
If you have your Windows7 disk or a repair disk boot into that by pressing F12 or F7 upon startup (sometimes different, depends on your computer).
The Win7 disk should allow you to repair the system files.
Also some manufacturers include a recovery partition (special way to boot your computer so you can repair it). Often you can check your computers manual but normally you just need to press one of the F# on startup
May 04, 2011 | Computers & Internet
Comaq presario cq 71 cursor is frozen. PC shop man siad it was poor battery. Booted up from mains and cursor worked fine until recently. Mistakenly left battery in and powered down to hibernate. Now cursor...
yeah ..you have to disable the power saving mode..This is the only thing related with the battery usage that may disable the cursor..o r..just reinstall the touch pad..
to do that download its driver and run it into computer ..
here is the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3795238&
just select eh operation system and download the touch pad driver..
or go to control panel ..open the touch pad icon ..and in there select default settings ..or enable the cursor again ..if it is disabled..
if this is not working ..try reinstall it like I said ..It always starts a clean installation from the factory settings ..
Avoid hibernate it ..cause will always preserve the last settings ..just close it proper each time ..this way it will boot and recognize devices each time from the start ..
Dec 06, 2010 | Compaq Presario CQ50-215NR Notebook
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
I cannot get to Display to return white so I can make changes
You need to disable themes. This can be done by booting up in safe mode (pressing F8 on boot and selecting safe mode) Then while in safe mode go to start(then)control panel(then)administrative tools(then)services and then find "themes" right click it and select properties then you will see an option that says "startup type" click it and select disabled. It should remove all themes the next time you boot up normally
Sep 22, 2009 | Microsoft Windows XP Home Edition
Vista theme changes to windows classic upon restart
Are you wondering how to change the theme back to the "Vista Theme?" If so open "Theme Settings" by clicking the "Start" button, clicking "Control Panel," clicking "Appearance and Personalization," clicking "Personalization," and then clicking "Theme," then choose your desired theme.
If you've done this already, then you have a problem, usually when your appearance settings won't stay the way you want them to, and they keep revering to something else, it means that you have a virus on your machine.
To fix this you can try several things, try booting up in safe mode, and then restarting your computer.
You can reinstall Vista, by using the "Install discs" that came with your machine.
Hope this helps!
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
E-yama monitor "out of range"
The fix was pretty easy in the end.
Instructions are based upon Windows XP Pro OS.
Re-boot computer but inerrupt start-up by pressing F8 (option will vary between computers)
Select SAFE mode but with VGA option in order that the screen will actually display.
Once fully loaded click:
Start
Control Panel
Appearance and Themes
Display
Settings
Using the mouse cursor adjust Screen Resolution sliding scale until the ratio matches your monitor e.g. 1280 x 1084
Then click Apply and OK (important to do it in this order otherwise changes will not be saved)
Reboot as normal and the monitor should now display correctly.
May 11, 2009 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
I'm not sure when it started, because my 17 year old son was the last person to use the computer. I have a 4-year old Dell PC and have been running Norton Go Back just about the whole time. Since late...
my advice is to uninstal Go back as sometimes it stops the boot process, but you may have a faulty drive, so first try starting in safe mode (Pressing F8 on boot up), select safe mode and if it boots into windows you know it's not a hardware problem, but a software one.
Sep 02, 2008 | Computers & Internet
Dell Dimension 4700 PC Desktop Logo
43 people viewed this question
Alun Cox
