Question about Logitech X-530 Computer Speakers
Logitech x-530 rear speakers and Center speaker not working
I have a custom built computer. Motherboard is the EVGA nForce 750i SLI FTW which supports 5.1 surround sound, however only one outlet gives any sound output and I have 3 jacks. To simplify, one outlet works out of 6, 3 jacks to plug in. I have a choice of the center left and right speakers with the sub, just the center speaker, or the back left and right speakers. How can I get all of the speakers to work?
You have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Posted on Dec 06, 2008
My pc doesnt do any beep and does not send any video at all
With SLI you may need to ensure you hook the additional power connector from the power supply to the SLI video card. TYpically, these cards require a power hookup.
Sep 21, 2010 | Evga nForce 750i SLI Motherboard & Intel...
Which of this boards are the good and stable ones
I assume you are running PC with Intel chipset.
I would recommend ASUS P7P55 WS SuperComputer its $199 at newegg.com
supports i3, i5, i7 LGA 1156 processors, which is quite a variety of speeds and power; supports DDR3 up to 16GB, 5x PCIe slots (though running at less than x16 if you use more than one or two); 6x SATA connectors; dual gigabit ethernet; the BIOS has plenty of options for overclocking, etc.
Jul 19, 2010 | ASUS P5N32-E SLI PLUS (0610839148967)...
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
Motherboard specs JM679 m6300
According to DELL, the compatible processors with this unit are the Intel T7700, T7500 & T2750, also model T1300
Sep 18, 2009 | Dell Precision M6300 Mobile Notebook
When connecting the leads to the sound card do i plug one into the pc. and should all the speakers work straight away,I only have thee woofer and the centre speaker working.. LOGITECH X-530
There are leads that need to be connected to your computer for the Front, Rear, and Subwoofer speakers Not all motherboards have all of these connections Your Logitech manual shows how to connect the speakers correctly if you do not have all of the connections on your motherboard
Sep 14, 2009 | Logitech X-530 Computer Speakers
Rear audio does not work
Hi the solution for the rear audio do not work is cold solder connection to the mother board or the banana plug female connector. You have to remove the mother board because you don have no access to re solder the the frame cover that area. If the female banana pug connector is the problem the parts is available at radio shack. Before you do all of what I mentioned first you have to confirm by going to control panel click sounds and audio devices and watch the screen and speaker will gray out if the speaker is un plug or not detected. If your PC use Realtek audio device on the control panel click the sound effect manager and click the speaker test tab and perform speaker test. Then if the test fail perform mother board repair. Hope this info might help you solve your PC rear sound problem.
HH
Apr 27, 2009 | Evga nForce 680i SLI (122CKNF68)...
Subwoofer and center box problems with Logitech X530
Hi Sainty,
this is just a shot in the dark, but have you attempted to play around with your sound driver's configuration? I'm unfamiliar with the newer Nforce stuff, but try looking around in the sound manager Nvidia uses. It sounds like it's been configured to swap speakers. (As an example, I'm using the realtek audio manager on an asus p5k-vm board myself, and the option shows up as "Swap Center/ Subwoofer Output" in my configuration.)
Dec 10, 2007 | Logitech X-530 Computer Speakers
Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Sep 22, 2007 | Logitech X-530 Computer Speakers
Help
maybe you should check the configuration of your built-in sound card.
Jul 04, 2007 | Altec Lansing ATP 3W Computer Speakers
Logitech X-530 Computer Speakers Logo
1,185 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
