Question about Whirlpool Microwave Ovens
Built in over the stove microwave installed with fan blowing air out of the front of the unit,{recirculating} and setting off our smoke detector.. I have installed ductwork to outside of house and want to redirect fan to top vent so as to vent directly to the utside.
  • 734 Answers
Please give detail of model number.
Posted on Dec 02, 2008
    Genius:
  • 1,124 Answers
Most of these units have a center conduct to connect to external. You have to remove the center cover to connect the external outlet.
    Sergeant:
  • 217 Answers
That will need a technician at your place as the section in the oven has to be made and some modification will require to do this.
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
I have a GE Spacemaker Microwave DE68-40861A that has a built in range vent. The fan motor blows just fine, but there is no airflow. Apparently this was installed improperly. What would be blocking the...
take microwave down. There is 1 screw on the back that hold fan in. Pull screw out and the fan will lift out. Roll fan so that opening of fins faces to the front. set it back in put screw back in and remount microwave.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My cooling fan will not engage when I turn on the microwave. I am manually turning on the fan at High to make sure the temperature doesn't overheat the appliance. Sometimes after I'm done cooking if I...
There are typically 2 fans in these units. The fan that cools the magnetron and then the vent fan that intakes from the top of your stove then vents the air out or away from the unit. Are the lights that shine on the top of the stove working?? Sometimes if a bulb blows violently it can blow a trace off of the back of the main circuit board and that trace may also supply power to the fan
Oct 21, 2017 | Magic Chef CMV1000B Microwave Oven
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Recirculation fan does not pull in air/steam/smoke
The issue is that the fan on that unit is a reconfigurable fan. If there is a vent, you install the fan one way, if there is no vent pipe to the outside, you install the fan another way. https://www.manualslib.com/manual/294916/Maytag-Mmv4205.html?page=9#manual
Sep 04, 2017 | Maytag MMV5165 Microwave Oven
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
