Question about HP Photosmart M22 Digital Camera
Hp photosmart m22 memory card problem
I recently switched to rechargable batteries in my camera and now i cannot format my 512mb sd memory card. are the batteries too high in voltage? i went a got a replacement card at staples and it still does the same thing. as soon as i turn the camera on it asks to format the card and as soon as i press ok it acts like it will but then goes right back to please format card. this is highly frustrating because i am used to taking multiple pics and videos which without the card i cannot do. any solutions?
    Champion:
  • 217 Answers
Rechargeable batteries voltage actually are lower than normal batteries, but is high when freshly charged or still hot after charging. don't use newly charged or hot battery, wait at least five minutes or let the batt cools down first. some model and brand uses compatible rechargeable batt, it is different from those sold individually which i think you are using. it has special switch activator attachment have you tried to switch back to alkaline? how about formatting the card in pc? try removing then reinserting the card for several times. this will clean the card contact point in camera.
Posted on Sep 08, 2007
Camera says "unabled to format, please replace card"
Check the SD memory card R/W switch.
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Oct 20, 2012 | HP Photosmart M447 Digital Camera
While cleaning out my elderly mothers house I found a Hp Photosmart M22. The memory card and batteries were missing. Otherwise it looks OK. I put in new batteries and a Lexar SDHC 4 GB memory card. It...
The M22 won't work with your 4GB SDHC card. It only works with MMC and SD cards up to 1GB in size. Having said that, if after cleaning the battery contacts and putting in new batteries, it still doesn't work, I'd toss it and get a newer camera. Giving its age and (lack of) capabilities, it just isn't worth repairing.
Mar 19, 2011 | HP Photosmart M22 Digital Camera
How do I unlock my Canon Power shot Memory Card Model SD 1100 IS
SD (and SDHC) cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 09, 2010 | HP Photosmart M22 Digital Camera
I got a 4gb memory card-SanDisk and the camera says it is unreadable.i had a 512mb card and it worked fine.
Hi Tomcat,
this will not work.
The HP 945 does not support 4GB cards.
4GB (or more) are SD-HC (High Capacity). This is new format which only will be supported by newer camera models.
Jan 10, 2010 | HP Photosmart 945 Digital Camera
Memory card
To transfer the photos, connect directly SD card to your PC through a card reader.
Try to reset your HP R707 camera: remove the battery and press the reset switch for about 5 seconds. Reinsert the battery.
Mar 26, 2009 | HP Photosmart R707 Digital Camera
Batteries
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
May 24, 2008 | HP Photosmart M22 Digital Camera
i still can't solve my problem with my camera.
the screen still displays a red color
Feb 21, 2008 | HP Photosmart M22 Digital Camera
Card formating
yikes!
Assuming you are talking about an SD card, no way that I am aware of. You might put your card into your comp and see if there's anything on the card.... sorry!
Oct 21, 2007 | HP Photosmart M22 Digital Camera
Won't read sd card - says card not suppoorted
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
May 21, 2007 | HP Photosmart M417 Digital Camera
HP Photosmart M22 Malfuction
use different memory card, most troubles i always encountered in digicam are caused by memory cards, many cards works in pc but not in digicam. hey tapping side by side always takes away the trouble. [;0)
Jun 21, 2006 | HP Photosmart M22 Digital Camera
HP Photosmart M22 Digital Camera Logo
70 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
