Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Linksys router befw11s4
I have an HP computer, with windows xp professional. I recently had problems after a power outage, and now I can't get an internet connection. IP is comcast. They can't seem to help me as neither can the techs at linksys. The wired computer tells me there is an ip address conflict, but no one can tell me how to fix this. All agree that the computer that I want wireless isn't recognizing the fast ethernet card. Any help would be greatly appreciated. Needless to say I am not a computer expert
  • 22 Answers
Re: linksys router befw11s4
Go to click start/click run/ type cmd/ type ipconfig / release - enter ipconfig / renew - enter if your default gateway has contact your router manufacturer so that they could give you the correct settings ping if it gives you numbers, you are connected already
Posted on Feb 01, 2007
  • 2,961 Answers
The easiest way to sort it is to enter your routers settings page in your internet browser or desktop icon and make sure you enable DHCP which will give your pc an automatic ip address. Make sure WEP or similair is off until the set up is sorted out. Next go to your properties of your wireless adapter(Card) and go to internet TCP/IP and click properties and make sur 'Obtain IP address automatically is ticked. No click Start, then Run then type:- ipconfig /flushdns then press enter.(note the gap between ipconfig and the /). Restart your pc and router and try connecting again
Posted on Jan 31, 2007
0 characters
3 Points
I recently reformated my computer and reinstalled windows xp. Before doing this I had the linksys wusb600n installed on my computer from the original cd. When I reinstalled my windows i copied the folder...
Try to Install this driver for Windows XP, directly from their website.
By the way, if your adapter's version is 1.0, its user guide is here. On the other hand, if it is 2.0, the corresponding user guide can be found here.
Hope you are able to sort your problems out soon.
Regards, Carlos
Nov 05, 2010 | Cisco Linksys WUSB600N Adapter Wireless...
No connections with my wireless on asus g72
It is a hardware problem. The switch on the Asus G72GX is at fault. I own the same machine, and the switch will hard-lock the wifi and will not unlock it. The hot-key will not work either. It took me a very long time to get to the root of the problem. The only solution appears to be to switch the wifi off, power down (restarting didn't work for me), turn the switch on and then power up.
Dec 12, 2009 | ASUS Network & Wireless Adapters
Linksys Wireless Adapter that will not find the internet
I think you might be using the Linksys utility.
you can switch over to windows utility if it is XP or VISTA.
that will resolve the problem.
make sure that it will be connected to the network and should have proper IP address
Click Here for more info about wireless network set up
Oct 12, 2009 | Linksys Ultra RangePlus Dual-Band...
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys Wireless B Router Compatible with Windows Vista?
I would advise you to purchase a Linksys G router, Model # WRT54G2. Works well with Vista and your other laptops will work also.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 26, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Before you can get online through the router all you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its, you need to change it to And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (
  2. Now you restart your computer to refresh the connection and that should get you online.
Just reply to my post to let me know if your done doing this. We will setup the wireless after we make sure that you can get online wired to the router.
May 13, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Intel Pro Wireless 2200BG problem or Linksys BEFW11S4 problem?
I had the same problem. If you are using the latest driver for your intel 2200BG ( Try to roll back to a previous version. It solved my problems with being unable to connect to a Linksys BEFW11 router running WEP64.
I am now running driver version
Oct 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
112 people viewed this question
Top Linksys Network & Wireless Adapters Experts
Are you a Linksys Network and Wireless Adapter Expert? Answer questions, earn points and help others
