2006 Buick Terraza Logo
Domenic Bettinelli Posted on Jun 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headlight sensor I need to replace the sensor that decides when to turn on my headlights when they're in automatic mode. In the middle of the day, the systems says my lights should be on and dims my dashboard lights. For some reason it also stops my left-turn signal from working. If I manually turn of the lights everything works again, but then my turn signal doesn't work at night and I'm always having to remember to turn the auto headlights off during the day.
Level 3:
  • Buick Master 19,187 Answers
  • Posted on Jun 10, 2017
Buick Master
Level 3:
Answers
19187
Questions
0
Helped
4345580
Points
82261
I have seen the sensor fall out of the dash housing. When you put it back it should be good again.
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Feb 13, 2009
SOURCE: dim headlights on 2006 buick lacrosse
check the earth wire first,wattage on the bulbs in case their wrong or old type bulbs ,check supply voltage ,if all ok then fit aux spot lights .if still having a problem have eyes checked as over 40 the old peepers can deteriorate ,dont know the name of it but it can affect some people at a younger age than others,glasses will not correct this problem.
Anonymous
  • 607 Answers
  • Posted on Mar 29, 2009
SOURCE: 2001 Buick Regal dash and radio lights dim when headlights on
sounds like a faulty headlight switch w/dimmer
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Oct 30, 2009
SOURCE: The headlights only work on Bright. The dim
could be dimmer switch,may heat up and kill lights or maybe headlamp switch, your at a point were you are going to have to replace parts,first thing is headlamp switch, take apart but leave it pulged in when lights dont work install new switch and see if that works, this is not a diffuclt problem dont know why dealer could not pin point,anyway start there, good luck.
dogwood32
  • 432 Answers
  • Posted on Jan 27, 2010
SOURCE: 1999 buick century. headlights won't come on
Sounds like you don't have power to the switch or the auto switch.When you pull on the turn switch you are just flahing the high beams.Almost all gm's will do that.Would try and check fuses or get a wiring digrahm and see were the power comes from to feed the switch.If you work on apliances its about the same.Well good luck
Anonymous
  • Posted on Apr 22, 2010
SOURCE: 1999 buick century headlights won't come on
no low beams on my 1999 buick century change headlight bulbs and still no low beams
1helpful
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Automatic headlight system
There is a light sensor that is responsible for turning on the lights in dim condition. Obviously, it is not working and needs to be replaced to restore normal operation.
3answers
On my 2005 Chevy trailblazer my headlights are automatic, randomly when I'm driving they turn off on my and my high beams still work. I checked the fuses they still work. Can someone please help me?
They are controlled by a photosensor, my subaru legacy does the same thing, switch from running lights to main headlights when in auto mode, if you want to leave the lights on all the time switch out of auto mode
1helpful
Headlights will not turn off automatically
it will turn off automatically if you keep them on Automatic mode, see the option of automatic mode over the Headlights ON/OFF switch.
1998 Lumina lights don't work at night!The lights work during the day but not at night. Does anyone know how to fix it?
Theres a sensor in the middle of the dash by the front windshield that detects sunlight and triggers the automatic headlights. The main headlights and daytime running lights might be on a different circuit, in which case they daytime running lamps would turn off at night and the main headlights would turn on, indicating the main headlights arent working and the daytime running lamps are working as intended.
I would check all the fuses related to headlights, check the bulbs and check the switch, then last the light sensor on the dash.
1helpful
Will Hyundai accent 2003 turn headlights off automatically when ignition is off?
Does your vehicle have daytime running lights? If so, it's a far more complicated system and you'll probably have to take it to a shop.
2helpful
Headlights won't go on
Sounds like a loose connection or a bad ground wire
The xenon headlights on my 2002 Audi TT quattro are aiming down. Can only see about 10 feet in front at night. Recently had the headlight sensor replaced & was told that the headlights would adjust...
go back to were you had the sensor replaced and have them repair the problem this should have been working properly before it left the shop.it could even be a bad sensor.
Headlights on automatic will not turn on in auto mode
you need a headlight relay fuse. it should be a big square fuse on the front driver side.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
