Question about Samsung RS2534 Side by Side Refrigerator
Ice maker still not working
Ok, so I went and bought a new module/motor. It came with a new tray. I installed it and ran it through a test cycle. Still the tray does not twist through its entire spectrum of travel. Maybe I dont have enough power coming to the motor? Is there a relay that you know of, or some sort of converter that supplies the 12v power this thing needs to run? Is that even a possibility of not getting quite enough power? There has got to be something I'm missing. Maybe the cycle should pause at the point it does for however long, I going to leave it be for a while and see if it eventually dumps the ice. -Thank You
  • Rachel Buck Feb 02, 2007
    The Ice Tray twists past the fill tube perfectly, however it seems to be intended to twist a long ways. The sensor that registers when it is time to dump had gone bad at some ponit in time. The tray that came with the new motor dumps fine, luckily. Although I still had to force the new assembly in order for it to turn all the way. What I did was refabricate the cam on the large cog to where it registers at the point of the tray dumping ice, even though it doesn't make the full twist. As far as I can tell everything is working now. I kept one good cog just in case someone comes up with an idea that helps me to fix my machine properly. If you have ever run into a failure like mine I would like to know what fixed it. I am thinking that the motor just doesnt receive enough power to twist completely, causeing the motors overload shutoff
  • to occur before it triggers the other switch. There must be a relay or power supply to this unit that isnt working completely. I can Also post pictures of what I did, and a breakdown of parts involved if it helps anyone else with this same problem. Let me know what you think.
    The part number on the motor assembly I bought is DA97-00258C. It cost me about $75, I saved a little money buying it locally but you can also get one here: http://www.bellparts.com/search_prod.php...
    This assembly is the 7 cube tray that produces cubes that look similar to little footballs or something cut in half. Very small unit. I understand it is NOT the most common thing seen. I mention these things, because there is no picture at the link.
      President:
    • 878 Answers
    Flayel, there was a service flash on this ice-maker. ASC20060525001. Has to do with the fill tube freezing up and the tray hanging up. As the ice tray twist to harvest, it gets hung up on the tube and is pulled from the mount position. They revised the fill tube, part number DA63-02928A. Now Im not saying this is your problem, but it's worth taking a look at. Catriver..post back.
    Posted on Feb 01, 2007
    My ice maker has ice in the tray but not dropping in Ben,it is a kfil27cxmso there is a lite that sends a beam across ben ,how do I check to see if the bulb is blown or working, gk
    Hello George;
    My name is Peter. I am a retired field service technician.
    I live in Baltimore, Maryland, USA.
    All ice makers work in the same way.
    Your fill cycle is working fine. You have a thermostat in your ice maker which tells your ice maker control module (Computer) that the ice cubes are frozen and ready for harvest. Then, then control module tells the cube tray heater to turn on for so many seconds, followed by the control module to activate the harvesting motor.
    So, your ice maker either has a bad thermostat, heater or motor.
    The beam across your freezer section is a safety device. On the right hand side is the transmitter. On the left hand side is the receiver with a plastic flapper. When you close the door the flapper closes and completes the signal to discharge ice. When you open the door the flapper pops out blocking the signal.
    Dec 02, 2014 | Refrigerators
    Kenmore WR30X0318 Ice Maker Stopped Making Ice
    The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
    Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
    Nov 14, 2012 | Kenmore Refrigerators
    AMANA FRIDGE SCD23VBW, NEW ICE MAKER WON'T CYCLE
    repairs should be performed by an authorized repair technician. D7824706Q complete ice maker should never be advanced manually. the ice maker arm should be in the down position in order to advance. once the inner thermal switch has been satisfied the ice maker motor should advance. the ice maker is damaged and will need to be replaced by the proper ice maker.
    Jun 04, 2017 | Refrigerators
    2003 whirlpool ice maker doesn't work
    May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
    Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
    Make sure that the ice maker is in "on" mode.
    May 03, 2017 | Refrigerators
    Ice Maker Won't Drop Ice
    you have a problem in the module of the ice maker if it is new take it back for a new one
    May 02, 2008 | Refrigerators
    Kenmore Elite - 106.55606400 - Ice Maker is not working
    This is the replacement for the old one they stopped making the 260w
    Apr 04, 2008 | Haier HRT02WNC Compact Refrigerator
    Fridge freezer door ice maker
    the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
    Jan 09, 2008 | Jenn-Air JCD2389G Side by Side...
    Ice Maker Overflowing
    i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
    Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
    RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
    press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
    Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
    Samsung RS2534 Side by Side Refrigerator Logo
    172 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
