Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint won't start
Moved machine to decorate.
Now won't start ?
Have checked fuse / plug and electric source
ANy ideas
  • Hotpoint Master
  • 3,463 Answers
If no lights showing at front of m/c, then I would suspect door lock not engaging
Posted on Dec 10, 2008
My hotpoint aquarius wmf560 won't turn on no power since I moved it from my old house yesterday any ideas ???
sounds like a blown fuse or broken wire
cut back the wire by 6 inch and rewire plug replace with 13 amp good fuse
Dec 17, 2015 | Hotpoint Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
see this causes and fix it. God bless you
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarias wd 420 hotpoint
sound like motors or heaters have a short good luck.
Sep 13, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarius 1200 WM64 - machine does not start
If you already replaced the fuse, next part to inspect is the control board behind the timer.
If that is ok, check the wiring harness, the socket and the power cord.
Feb 03, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint WD63
Sometimes the door lock doesnt engage properly! This could be the cause, give door a good slam shut. Hope this is of help.
Jun 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf210 No light at all
I cannot tell you how to fix, jut trouble shoot.
Turn off power and unplug.
Do a visual inspection of all electrical connections you were working close to.
Re-check every electrical connection you had to disconnect and reconnect - remove and reseat.
Regards
Jan 06, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
