Can aphotosmart c7280 all in ne do duplex printing
  • 40 Answers
The printer’s built-in duplexer lets you print on both sides of a sheet of paper, but there’s no duplex scanning for two-sided documents. taken from Mac Life last sentance 4th paragraph Please rate my service thank you  PJ
Posted on Dec 02, 2008
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Can you print w/o the duplxer on the back of the hp photosmart c309?
Its not possible without the duplexer but if you have any other older photosmart like C6180, C7280 then there would be a rear door which is attached to it which you can connect at the back of the printer and make it work or might be you can get it from a repair shop, it would be much cheaper than repair shop
Oct 22, 2010 | HP Photosmart Premium C309A All-In-One...
HP C7280 doesn't print 2-side from my computer
have you use duplex unit?
you have to change your driver option both side print
Oct 27, 2009 | HP Photosmart C7280 Printer
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
HP C7280 duplex scan problem
click on start and select control panel.
in control panel on the top left hand click on switch to classic view if is not there dont worry.
Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
IN vista
Click on start
in the start search box type "printers" and click on ok.
Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
May 29, 2009 | HP Photosmart C7280 Laser Printer
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Cannot get printer (hp C7280) to print double sided
There is a new driver from april 2009 on HPs site which adresses this problem. I installed it, and now everything works fine. You have to download and install it yourself, it doesn´t update automatically.
Apr 26, 2009 | HP Photosmart C7280 Laser Printer
If you read the troubleshooting section about paper jams (in the book) you will see that you clear paper jams by unclipping the duplexer at the back of the printer. It has two quick-release buttons on the sides - just push them in, it pops out and you can clear it. My 85-year-old mother had the same problem.
Apr 19, 2009 | HP Photosmart C7280 Laser Printer
C7280 printer will not duplex print
This only happens using wireless.
plug in the usb port to the pc
let it install automatically
turn off pc, unplug printer
turn on pc, adj printer prefs for wireless
Aug 03, 2008 | Office Equipment & Supplies
120 people viewed this question
