Question about Maytag Neptune Washer
Wont stop filling up with water in ther rinse cycle
What can I do
    Problem Solver:
  • 7 Answers
I saw this on another forum. Replace the "machine board". If you can solder you can repair yourself.
Do a search on "Maytag Neptune R11 burnout". I have the notes. It is either Q17,Q9,Q3 triacs. They should be 600volt not 400volt. Could be the Transistors 400volt Q2,Q7. Replace with 600volt.
These boards have many probs. I would replace it.
Posted on Feb 18, 2009
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Wont rinse
As rinse cycles are cold fills you may have a problem with the cold water supply valve. If you put your machine on a cold wash only and it does the same thing this problem should show up while filling and lead you in the right direction for repairing it.
Dec 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Feb 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
