Question about Bernina Artista 180
How do i oil my bernina 801?
Oiling bernina
  • Anonymous Mar 16, 2014
    do buttonholes Bernina 801
    how to do buttonholes on a bernina 801
  • 19 Answers
Please do not oil anything with WD40, it is an alcohol based cleaner hense why it's flammable. No where on the container will it say anything about lubricating, it will merely dry out your machine. We use it, but only to clean metal parts... we then clean it off and let it evaporate for a day before applying oil.
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
Help.....I'm not an accomplished seamstress but have done my share of sewing....."in my earlier years".....in my 702 now. My problem is.....I have a Bernenia 801....great machine, never had problem one.....but haven't used it more than 2-3 times during the past 7-8 years....no maintenance service during that time as well.......Problem:......recently I was sewing a long seam...speeey like.....it began to sound a little like my bobbin was jumping.....getting a little louder every little bit....about the time I decided it must be something serious the maching just....stopped.....totally stopped.......Now I know nothing broke, I'm positive the bearings were just completely dried out from lack of use and maintenance.....Again, my many years of experience know nothing broke.....so what can we do to fully lubricate the machine and possibly work it free......I live in a little remote boonietown in SW KS and tho there is a dealer/serviceman in Dodge City I've been warned NOT to let him touch my machine....Several friends tell horror stories about his "repairs".....This leaves me having to take my machine clear to Wichita for repair........4 hours away, and we don't make trips very easy and definitely not often to Wichita......Help, any and all infor will be appreciated.
Posted on Aug 26, 2010
3 Suggested Answers
RickE1
  • 202 Answers
SOURCE: I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Posted on Oct 08, 2009
  • 19 Answers
SOURCE: how do i oil my
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
I have a bernina 801 sewing machine. I am unable to dis engage the wheel to reload the bobbin, it will not turn
Have you ever lubricated it? Sewing machines must be periodically cleaned and lubricated or they will get stuck and freeze up
Nov 20, 2014 | Bernina Sewing Machines
Why the lever won't move from straight stitch to other stitches on my bernina 801?
thats a 50 year old machine...its seizing and needs oiling and service
Sep 17, 2014 | Sewing Machines
Bernina 801 squeaking squelling noise
Needs oiling and cleaning. Use good quality sewing machine oil, NOT 3-in-1, WD-40, or cooking oil.
Jan 06, 2013 | Sewing Machines
Hand wheel will not release on my bernina sewing machine what should I do?
If handwheel is difficult to turn manually, it most likely needs cleaning and oiling.
Oct 11, 2012 | Bernina Sewing Machines
Bernina 801,feed dog knob will not turn.
Most likely needs a good cleaning and oiling. The old oil has dried out and become gummy, causing the moving metal parts to stick.
Apr 16, 2011 | Sewing Machines
Bernina Record 930 Electronic, seldom use, like new. Wheel will not move. Was doing stright sewing, machine slowed down then froze. Maching is clean. No instruction book or manual. Machine belongs to my...
Bernina 930 Records are notorious for the basting stitch sticking which eventually locks up the machine. To prevent this from happening, be sure to run the basting stitch for a few minutes every month. If it is stuck, you'll need to take it to a Bernina technician.
If it is not the basting stitch, it could be a broken plastic gear (trip to the Bernina technician) or it needs oiling.
If it is not a broken gear, then it probably needs oiling. Your Bernina mechanical requires regular oiling and cleaning even if you don't use it (ie, every time you change the bobbin, every 8 hours of sewing, or every 6 months if not in use). HINT: recommend Bernina oil or similar good quality oil for mechanical machines, NOT 3-in-1 oil, WD-40, or cooking oil!!! One or two drops of oil in every oil hole and every place that metal part rubs against metal part.
Treat your Bernina well and it will serve you well for many years.
Oct 23, 2009 | Bernina Sewing Machines
Rick
Sep 20, 2009 | Bernina Sewing Machines
Bernina 801 Sport
Did you clean out the lint under the plate?
Feb 27, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
1,456 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
