Question about Zanussi FJS1225W Front Load Washer
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
When removing clothes after wash I noticed a clunking noise - thought it was a coin or similar in the drum, but nothing there. When rotating drum by hand it feels as if it is running over an obstruction once or so every rotation. Haven't run it under power since.
I assume there is an outer and an inner drum - is it possible for something to get trapped between the two drums?
If so, is it a DIY job to remove the item, or should I give up and get a professional in?
  • 1 more comment
  • mark_ogilvie Dec 02, 2008
    Sorry, this is a WDJ 1094 washer dryer (Turbospin 1000) - not sure how I got the wrong model, first time I've used this site!
  • mark_ogilvie Dec 21, 2008
    Thanks for the suggestions - I got as far as opening up the back and having a look, thinking about removing the sump hose and then deciding it was maybe a job too far for me without a bit more consideration. The machine seemed to be working ok, so carried on using it. Then, rather bizarrely, after 3-4 washes the gravel appeared inside the inner drum after spinning, with the clean washing! No problems since. How did this happen? Was I temporarily in an anti-centripetal forcefield?!! Anyway, fixed itself without any intervention from me, which is my favourite kind of fix!
    Thanks again for your help.
  • pedropony2 May 11, 2010
    It is sometimes possible to get it out by removing heating element and fishing but with zanussi this is not a 5 min job. however if you would like to have a go post back and i will guide you through it.
  • 135 Answers
Hope your problem was solved.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • Zanussi Master
  • 3,463 Answers
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Posted on Dec 08, 2008
Loud noise during spin/rinse cycle
Probably a coin or something in between the 2 drums being thrown around. You will have to remove it somehow if it is as it will damage the drums. First check for any loose parts in the case that may just be knocking around and then try and see if you can see anything in between the drums by useing a light and looking through the holes in the inner drum. If you see anything that should not be there it will need removing. May be possible to get it out by removing the lower drain hose from the outer drum, the door seal if a front loader or the heating element. Start with the easiest to remove first.
Dec 31, 2012 | Maytag Washing Machines
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Clunking in the frount
A clunking sound in the front is very often the CV joints. This should be more obvious in a slow tight turn. If it is not the CV and is more noticeable on rough roads it could be any one if the suspension joints.
Apr 12, 2011 | Chevrolet Cobalt Cars & Trucks
Our Washer has a loud "ticking" noise in the wash
Could be something like a bra strap between the inner and outer drums. need to remove the agitator and inner drum to investigate and remove.
Could also be a bearing in the drive gearbox, if this is the case the machine is not worth repairing as the box is sealed and not serviceable.
Nov 29, 2010 | Admiral AW22 Top Load Washer
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-Fold® Projector...
Noise while spinning. Probably a missing coin and part of an ink pen that are missing but not in the tub.
there is an inner and outer tub it may be trapped in between the two. can usually pull aggitator and remove inner tub to check
Aug 01, 2009 | Kenmore 44102 Front Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
443 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
