Question about Nintendo GameCube Console
Three red lights
Our unit is about 1 1/2 old and was registered. my son got those "three red lights" need to return for replacement. what do i do??
  • 124 Answers
Call 18004MyXbox and get through the menus and get to Repair 360.
Posted on Dec 03, 2008
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
May 19, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
I'M REPLACING AN OLD LEVITON ROTARY DIMMER WITH A LUTRON PADDLE DIMMER. THIS IS A 3-WAY SWITCH. THE ROTARY DIMMER HAS 2 BLACK WIRES, 1 RED, AND 1 GREEN. THE NEW DIMMER HAS 1 BLACK WIRE, 1 RED, 1...
with a three way switch like this, you will have two traveller wires and a common wire. Look in the instructions for the switch or on the back of the device itself to see if there is a wire labeled "common" or "com". This common wire from the old switch hooks up to the common wire on the new switch. I did a bit of searching on the leviton 6602, but couldn't find anything specifically about the three way version (I would venture to guess, however, that the red wire on the old switch is the common). The common on one of the three way switches will always be a constant hot (or power) wire...the common on the other three way switch will be the "switch leg" or the wire that connects directly to the light. The two travellers go to the other two wires. Check the pamplet that came with the lutron device, it should show which wire is common and which are travellers.
Sep 24, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
My son's XTC has a frozen keyboard. All that
Call Virgin Mobile and get a replacement sent out. You have a 1 year warranty..use it!! I have had my daughter's replaced twice due to it shutting down and locking up. This usually happens during a heavy texting day.
Jan 08, 2010 | Cell Phones
Nintendo DS won't power-up
It sounds like a faulty battery. As it is under 1 year old, it is still under warranty. Return it to the origional place of purcase, who will either fix or replace it.
Aug 19, 2009 | Nintendo DS Lite Console
My xbox has three red flashing lights, how can I get it working again?
My sons Xbox had the 3 red lights! It depends what colour of light is showing on your power pack the colour indicates what the problem is! The light will either be red,amber or green, my sons light was amber and that was due to a faulty power pack, Microsoft were very obliging and replaced the power pack free of charge,it arrived in 3 working days! Here is a link that will take you through the different lights and how to fix the problem!
http://support.microsoft.com/kb/907534
Hope this helps, good luck!
Jul 04, 2009 | Microsoft Xbox 360 Console
Headset CS50
It sounds like you need to re-register the earpiece to the base. To do this, use the following steps:
1. Return the headset to the
Headset Docking Cradle
2. Press and hold both the
Speak Volume Adjust Buttons (+/-)
on the back of base unit for a
minimum of 5 seconds. The
Red Power Indicator will then
flash
3. Press and hold the Headset
Mute Switch (black button on top
of earpiece) for a minimum
of 5 seconds. The On-line
indicator (green light on boom)
will then illuminate.
4. Subscription completion is
indicated when the Power
Indicator is fully illuminated
and the On-line Indicator is
extinguished.
5. If subscription fails within 2
minutes the headset will return
to the un-subscribed state.
Aug 19, 2008 | Plantronics CS50 Wireless Headset
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
Three red lights
three red lights (no error message) - two reasons for the red lights: hardware failure or power supply unit failure.
when the three red lights is showing check the light on the power supply unit. if the light is green you console is experiencing a hardware failure. you need to send the console to MS service center or if you have no MS support in your country look for someone who knows how to repair the console or go to xbox-scene.com and look for information on how to repair the console yourself.
if the light is orange, red or no light at all, there might be a problem with the power supply unit. disconnect and reconnect the power cables from the 360 and reconnect them again. if there is an inter-cooler connected at the back of the console, remove the inter-cooler and turn on the console without the inter-cooler. try also a different wall socket and if the light on the power supply is still orange, red, or no light when you turn on the console you need to replace the power supply unit.
Jan 18, 2008 | Microsoft Xbox 360 Console
2yr old Pioneer pdp-506 50" panel with seperate receiver unit
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
Jan 02, 2008 | Televison & Video
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
