Question about Photography
Manfrotto Tripod head 390RC2 falling apart
Brand new tripod and it's falling apart? The main lever below where the camera sits is very loose and I can't see or find any way to take it apart to tighten it? Is there a diagram that shows how these heads are put together?
  • 27 Answers
I messed with it myself until it finally came apart, found the hidden golt and tightened it, thanks.
Posted on Dec 03, 2008
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
I need instruction manual for manfrotto 058b tripod
There is a red slider under the main casting that will release the legs all together.
Apr 13, 2013 | Manfrotto 058b Triatt Camera Tripod Black
The head of my dynex tripod is loose how can this be repaired?
There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Sep 13, 2010 | Dynex 60" Universal Tripod
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
Lost quick release clamp on tripod (manfrotto)
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Jun 28, 2010 | Manfrotto Camera Supports 3405BN JR. BLK...
Tripod head
If the head is loose on the tripod follow these instructions:
There are three small set screw (grub screws) that are under the head, net to the center column. You will have to raise the center column and look under the head. These are slotted screw heads and a small to medium screwdriver should work. You don ot have to remove the grub screws completely, but you should back them out at least half way. The head will unscrew off the center column. The gray part below the head is half the head attachment and half the center column end plate so it should separate in the middle line between the two.
If screws came out elsewhere, we will need to know the model number of the head that came apart.
Jun 01, 2010 | Manfrotto (Distributed by Bogen) 055XDB...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
Attaching head to tripod
video cameras come with a 1/4-20 threaded socket in the.  Make sure the 3066 has this size screw projecting form the place where the camer is attached.  The two Manfrotto should be compatible
The only time fitting together becomes a problem is if you are into the heavy duty professional equipment.
We especially like the Manfrotto fluid heads and have several in our facility.
Nov 01, 2008 | Photography
Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
May 06, 2008 | Manfrotto MagFiber 190MF4 Tripod
Photography Logo
326 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
