Question about Gigabyte Computers & Internet
Cant overclock at all
Firstly, i used the  easy tune to overclock but didnt work so   entered bios .... here I increased the fsb from 333 to 360 but no luck....then i set the pci express bus to 100 mhz , memory multiplier to 2X but it wasnt going to boot.....lastly tried to underclock but that didnt work as well......are there any solutions?
  • killer_999_2 Dec 03, 2008
    Motherboard: Gigabyte GA-G31M-S2C
    Processor: Intel Core 2 duo E8400 @3.0 GHZ , FSB:1333MHZ, 6MB L2 CACHE, PCG 06.....Ver #:E43836-001...Prod Code: BX80570E8400...S-Spec: SLB9J...MM #:899035
    RAM: DDR2 800 2 GB TRANSCEND RAM........DRAM Timing Selectable (SPD) - AUTO
    CAS ..                                     -  5         auto
    DRAM RAS# TO CAS# DELAY  - 5         auto
    DRAM RAS# PRECHARGE       - 5         auto
    PRECHARGE DELAY (tRAS)    -18         auto
    VCORE : 1.236(in bios) .. 1.072/1.056 in CPU-Z
    DDR : 1.936 V
  • Howard Lester May 11, 2010
    Overclocking is a bit of an art.There are some things I need know before I can help you.First of all what motherboard model do you have? What processor do you have not just the manufacturer, but the model as well.What brand and speed of ram do you have? What are the clocks on it. A number like 5-5-5-18. What is the voltage of the ram? What brand of video card do you have? Lets start with these first and go from there.
  • 341 Answers
Thanks for the info. Here is what I see and this is my humble opinion as I buy everything with overclocking in mind.
Your processor is great for overclocking. these babies will go over 4 gigs on front side bus change alone. That's really all you can do with an 8400 since the multiplier is locked at 9 max. I did some research on your motherboard and according to the forums it's a reasonable overclocker too.Unfotunatly your ram is going to limit your performance. You have to use ram that is meant for overclocking because since you are changing the fsb your ram needs to be able follow that increase.Ram makers build extra "headroom" in their extreme series ram. Used to be you paid a heavy premium for this,but ram is so cheap these days it really isn't an issue these days. First off, get ram that is DDR 1066 and not DDR 800. Being that you are increasing fsb the reason is obvious.Check this ram out. It is exellent for overclocking and with rebate it is 43.00 for 4 gigs at 1066 mhz in two sticks.So get the ram and post me again.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289&cm_sp=DailyDeal-_-20-227-289-_-Homepage
Posted on Dec 03, 2008
    Problem Solver:
  • 5 Answers
Some mothere boards do not alow over clocking its bes to ask where u buy the mother board / cpu if it is posible to overclock
Posted on Dec 02, 2008
Help me please !
unknown cpu is Detected, updating bios is Required to unleash its full power. How can i setpe?
lga775 socketmaximus series Motherboard +DDR3 Ram+Intel core 2 Quad 3.0(Q9650)
Posted on Mar 14, 2011
I cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
Overclocking aopenax4b-533 mobo
In some motherboards, you can increase the multiplier, which will increase your processor speed.(Briefly, Processor Speed = FSB x Multiplier) You can also increase the chipset, memory, and CPU voltage, which will sometimes allow you to have a higher FSB. There are other settings such as PCI Bus and AGP Bus, you generally don't want to touch those, either they might put risk to your PC, or that they won't make much difference in performance. Be careful when you overclock because you can really damage your computer that way.
Mar 08, 2010 | AOpen Computers & Internet
HOW CAN I OVER CLOCK MY E7500 PROCESSOR??
Its so easy a child could do it, here is a link with step by step video guide as to how to over clock a computer, any problems get back to me as I am a expert with comps.
And please dont forget to rate me as this will help me to help others.
Here is the link.
http://www.wikihow.com/Overclock-a-PC
Cheers man
Feb 13, 2010 | Computers & Internet
My processor is rated at 3000 but is only running
What you are trying to do is called overclocking, and there are some excellent guides for that on the internet, like here: http://www.compunamics.com/overclocking.htm
I suggest you read this before proceeding the overclocking.
You can open the BIOS (press a key like F1, F2, F8 or del during startup). Somewhere there will be a menu with options for voltages and frequencies (units in V and MHz)
As you have read, processor speed depends on the multiplier and front side bus speed: CPU Multiplier x FSB = CPU frequency.
Right now, your frequency is 2200 MHz (presumably 11 x 200)
To get it to 3000 MHz (3GHz), you either have to raise the option called FSB in the BIOS to 270 (270 x 11 = 2970), or increase the multiplier to 15 (200 x 15 = 3000). Before you do so, write both the values down, so that you can reset to them, in case things go wrong.
I sugest first trying to raise the multiplier from 11 to 15. It may however, be locked at 11. If you can get it to 15, you're done, your CPU is now running at 3 GHz.
If not, you'll have to go through some more trouble.
First, you'll need to find your memory (or RAM, or DDR) multiplier and frequency, in the same menu as the FSB and CPU multiplier. Write them down as well.
As you have also read, increasing the FSB will make your CPU and memory go faster. This may however, be too much for the RAM to handle.
With the FSB frequency and multiplier, you can calculate the frequency of your RAM just as with the processor.
You will now have to change FSB from 200 to 270, so you'll also have to calculate a new RAM multiplier, if you want the RAM to run at the same speed.
For example, your RAM frequency can be 200 (FSB) x 2 (multiplier) = 400. If you then increase FSB to 270, your RAM will run at 300 x 2 = 600. You will have to lower the multiplier to get as close to 400 as you can get, and preferably lower, if 400 cannot be achieved.
Having done this, you can slowly start to increase FSB, I would suggest by 10 at a time. As soon as the PC has trouble starting, in the BIOS, increase the CPU voltage by one step, until it runs stable again. However, as your CPU is rated at 3GHz, you shouldn't have any trouble with this,and should not have to increase voltages.
If you encounter any probems, let me know!
Dec 15, 2009 | ASUS A7N8X-E Deluxe nForce2 Motherboard
How to overclock Intel Pentium Dual Core E2140 1.6 GHz processor
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
Dec 06, 2009 | Intel Computers & Internet
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
2.4GHz 533MHz FSB to 2.4Ghz 800MHz FSB
Yes, you can put any Pentium 4 or Celeronsocket 478 processor in there, including those with an 800MHz FSB onthe processor. Don't waste your time with only a faster FSB unless youjust happen to have one laying around, the performance won't improvethat much. This one is $50 from Newegg.
Upgrading the components is not overclocking. Overclocking is when youforce the components to run faster than they are rated for. Yourmotherboard is set up to allow this, through the BIOS. Severaloverclocking features areintegrated into the BIOS, including the ability to adjust the FSBfrequency, and the Vcore, DDR, and AGP voltages.
If you choose to overclock, be prepared to make frequent changes toachieve best performance vs. stability. I would suggest upgrading yourcooling to the best you can afford as well. Your PC may lock up orrefuse to boot for no apparent reason if you overclock. Be preparedfor that and know what to do about it before you start youroverclocking career.
Mar 17, 2009 | ASUS Computers & Internet
Overlocked my Intel Pentium 4 3.00 Ghz
You have to go into your bios and see what your front side bus and memmory speeds are. If you overclock you cpu, sometimes you need to underclock your memmory. Say step your memmory down to 333mhz and overclock your front side bus(fsb).
Normally your fsb is 200 and only increase it by mhz. Restart, go into windows. and see if it is stable.
I always use cpu-z and gpu-z to check all of my hardware settings. I use ati tool to overclock my x1950 and it is great. There really isnt any good cpu overclocking tools because its better to do it in the bios.
Do a specific search in google for your processor and overclocking.
Jun 06, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Overclocking past 2.7GHz with Q6600 GO step
Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
May 28, 2008 | Foxconn N68S7AA-8EKRS2H nForce 680i SLI...
Computers & Internet Logo
625 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
