Question about Copystar CS-2030 Copier
Hello there! This is the first time that our printer needs to have the toner cartridge changed, we dont know where to locate the old toner area
  • 145 Answers
If you open the fron door you can't miss it"s a big box there is a lever you may need to release so you can slide the toner bottle out
hope that help
Posted on Dec 06, 2008
Were is the toner cartridge located
Hello, The toner/drum cartridge in behind the front cover. I have put you a website to get a manual that explains where and how to change the toner.
Product Support
Click up there
Please rate my answer, thank you.
Sep 15, 2014 | Dell 3010cn Laser Printer
Printer is leaving yellow streak down right side of paper
That usually happens when a toner cartridge is getting low or old.
Replace the yellow toner cartridge. If you have done that then the other most likely solution is that you need to change the drum.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Printed page has a blank stripe through the centre. Have changed toner cartridge and same result. I understood the imaging drum is built in to the toner cartridge. Any suggestions? The printer is quite...
Remove the toner and look in the area above where the drum sits, there is either a glass that needs wiping or a shutter that may not be opening all the way. That opening is where the laser image is sent to the drum. Use a mirror if you can't see the area very well.
Jan 10, 2010 | HP LaserJet 4L Printer
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
Fain printing
I'm using remanufactured toner provided with my ML-2010 by Discount City when I purchased the printer and I'm having the same problem.
I have used non OEM toner in other laser printers also with disasterous consequnces so I think you'll have to 'bite the bullet' and purchase a new Samsung toner cartridge unless you can find out who manufactures the cartridge in which case you might be able to souece one directly avoiding the extorionate mark up.
Jun 19, 2008 | Samsung ML 2010 Laser Printer
Refill toner konic minolta 1350w
hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Mar 19, 2008 | Konica Minolta PagePro 1350W Laser Printer
How to remove or change toner
If you dont have the user's manual, here you have it online :
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
Look at page 24 - "Installing the toner cartridge" where you'll find this, but also pictures to illustrate how to do it.:
"1 Grasp the front cover and pull it toward you to open.
Note: Because the printer is very light, it may be moved when you
use it; for example, when opening/closing the tray or installing/
removing the toner cartridge. Be careful not to move the printer.
2 Remove the toner cartridge from its bag and remove the
paper protecting the cartridge by pulling the packing tape.
3 Gently roll the cartridge 5 or 6 times to distribute the toner.
Thoroughly rolling the cartridge will assure maximum
copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth
and wash clothing in cold water. Hot water sets toner into fabric.
Cautions:
• To prevent damage, do not expose the toner cartridge to light for
more than few minutes. Cover it with a piece of paper, if left
exposed for more than a few minutes.
• Do not touch the green underside of the toner cartridge. Use the
handle on the cartridge to avoid touching this area.
4 Locate the cartridge slots inside the printer, one on each side.
5 Unfold the toner cartridge handle and grasp it. Insert the
cartridge in the printer until it snaps into place.
Note: Carefully insert or pull out the toner cartridge not to scratch
against the printer.
6 Close the front cover. Make sure that the cover is securely
closed. If the cover is not firmly closed, printing errors may occur when you print.
Rate the answer please.
Mar 08, 2008 | Samsung ML 2010 Laser Printer
Refilling Printer Cartridge
  1. you didnt pay to have attention
  2. dont use recycled if you dont want problems
  3. this problem area is for a laserjet 1500l printer it does not use ink it uses toner
  4. You posted your question twice
Dec 29, 2007 | HP LaserJet 1500L Color Printer
Copystar CS-2030 Copier Logo
32 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
