HOW DO I PRINT A DOCUMENT IN 'LANDSCAPE' MODE ON SERIES 'X6150' SERIES PRINTER?
  • 40 Answers
Most douments under 'file' on the tool bar there will be either a 'page set' up  or 'print' Simply click page setup and you will see orintation landscape or prtrait the same is trew if you click print and then prefrences.
Please rate my answer
Posted on Dec 02, 2008
How so I do Landscape orientation on Canon Pixma MP500?
When you want to print a document Click on File (at top left hand corner of screen) - click on Print then click on Properties box - Layout tab then select Landscape.
The printer normally defaults to Portrait but sometimes you want to print Landscape. Use this method when you need to print in landscape mode.
Sep 07, 2012 | Canon Pixma MP500 All-In-One InkJet...
Output is sent to the printer and it prints portrait instead of landscape. This should be automatic. I should not have to select.
reinstall the driver ...this should fix the problem ...remove the other with the setings and the folder ...reinstall the driver and in main thought it should have a clean start ...
if it still does the same it is from the document you try to print ..it was saved by default in landscape mode...
also check the settings on the wizard ..when you print from word or other document a wizard starts and it has some settings ...change there and click apply...to save the choice ..
Jan 28, 2010 | IBM Infoprint 1332 Laser Printer
How to print document in landscape
This can be set in the properties of the printer mentioned. you can also request the landscape format in the software you are using. for most printers it is found in the TABS: finishing, paper setup.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
UNABLE TO PRINT LANDSCAPE
To print photos in landscape orientation use Irfanview. Install this software and use it to view photos. Very easy settings are available in print options from its options menu.
To print documents in landscape, choose landscape orientation from page layout.
For all other applications, set the orientation from the printer's properties inside the control panel in Windows.
Note: You cannot adjust it to print in landscape for direct copying from the printer's panel.
Dec 03, 2009 | Canon PIXMA MX310 All-In-One Printer
When printing duplex the even pages print portrait and the odd pages print landscape...
This could be a setting on the printer, in the driver on your computer, or the document you are printing.
First, try printing a different document and see if the problem persists.
Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset
You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
Sep 08, 2009 | HP LaserJet P3005 Printer
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
I need to flip my text to print on a transfer for a t-shirt
You want to flip the text? Do you mean you want the text to display 90 degrees from normal portrait mode into landscape?
If so, when you select a document to print a window should pop up with options to select number of copies, etc. Take note of a pull down menu with portrait, and landscape options.
Use landscape to print your job with the text in this mode.
If you want this set as the default option you can set this in your print settings in the computer.
Open your printer settings in control panel, (assuming you use windows) select the printer with right click, and choose properties. There should be an item labelled document preferences. In this you can select a between Portrait and landscape. Hope this helps.
Feb 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
May 30, 2007 | Printronix LaserLine L1524 Printer
95 people viewed this question
k24674
jasbo
jasbo
