Question about Epson CX3810 Stylus Color All-In-One Printer
Copying Problem When I copy something, only a portion copies and the rest of the page stays white. The cutoff is a very definite end, no fuzzy or fading edge where the copying stops. What is the solution for this problem? Thank you for your help.
  • 944 Answers
This sounds possibly like a page size problem. Here is the link to all the driver/manual/troubleshooting for your model; http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=60421&prodoid=56291069 try pressing either the "fit to page" or the "a4/letter" button and see if you get any change. Also if you often turn this printer off using an external switch (like a power strip switch) or if you often have power blackouts, there is a possible fault caused with the ink cartridges that may be the problem, the solution being to replace the cartridges - this doesn't sound like the problem unless you get the same when you print. Only other thought is that you may be placing the document to copy in the wrong corner of the scanning plate. The top left as you look at it should be correct, but just check putting a document in all the corners and see what you get. If none of this helps, then I suspect that the data cable linking the scanning carriage to the rest of the machine has a loose coneection or similar that is disconnected when the carriage moves past a particular point on its route. If you fancy trying to repair this yourself, it may not be too difficult, but the issue would probably be best solved by an authorised repair centre. follow the link above for details; Hope this helps :)
Posted on Mar 20, 2007
Hp officejet 6500 wireless TOP OF PAGE CUTOFF
Have you checked to see if you are printing with borders or printing borderless (under Preferences/Advanced)? I had this problem when printing double sided, since it will only be able to print double sided with borders...
Jul 11, 2012 | HP Officejet 6500 Wireless All-in-One...
There is a line down the middle of all pages when copying. The quality of the copy is fine otherwise.
Sounds like the glass for the scanner portion might have some gunk on it. Because the page moves across the scanner, a dot on the glass translates to a line on copies. There is usually a button or a handle to pull to get access to the entrance of the scanner portion of the machine. With a flashlight, inspect the glass at the scanner portion input carefully and use a paper towel and watered down windex to glean off any spots.
Jun 01, 2011 | HP 640 Inkjet Fax Machine
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Copying problem kyocera mita 3530
You did not specify how much of it it is NOT copying or left off.
Depends on how close to the end it is copying.
Try this make a copy of the ceiling ( open top with no documents and copy) it will give you a black sheet of paper, compare it to your copy, there is a margin of white around the black area this is because :
1- makes sure the toner is falling on the sheet
2- leaves enough room to clear out of the fuser.
Is your print falling in the white area? if so it can be adjusted but there has to be a margin of white around the paper. or it will cause jamming.
Good luck
Nov 15, 2007 | Office Equipment & Supplies
Epson CX3810 Stylus Color All-In-One Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
