Question about iLO (2 GB) MP3 Player
ILO mp3 2G locked up
I just bought my ILO 2 weeks ago, and now am unable to use it. Everytime it powers on, it will load a song list and lock up -I can't even power off. I have replaced the battery and erased all songs. I was listening to the tuner before this started and up until then had no problems. Please help
  • 1 more comment
  • Anonymous Feb 03, 2008
    how do i format the ilo mp3 player
  • Anonymous May 30, 2008
    My MP3 player is doing the exact same thing and I am having no luck. Please help!
  • Anonymous Dec 31, 2008
    its a pice of ****
I have An ILO MP3 Player My Battery Died and Now it just blinks. How Do I fix
Posted on Feb 03, 2008
Format the device.
Posted on Feb 12, 2007
Ilo mp3 player
take it back and try a nother one if you get the same problem then i suggest you perches a hub carrier with it own power sorce as all mp3 need 2.0 or moor
Feb 04, 2008 | iLO (2 GB) MP3 Player
Won't play
Sounds like the download is corrupt, delete data and download a single known good mp3 file and retest
Nov 07, 2007 | iLO (2 GB) MP3 Player
MP3 Player Locks up
Hi
you need to reformat your mp3 to software or to upgrade.
Jan 19, 2008 | iLO (2 GB) MP3 Player
Deleteting songs
If you are using windows media player, whatever is on your sync lists will be added to you ilo and what is on your ilo that is not on your synch list will be deleted from your ilo, when you udate your sync.
For example say on your ilo you have only one album from oh I don't know lets say....Beefheart and on your synch list you have the Monkey's greatest hits and five different re-mixes of the Macerana. When you sync up, the WMP should take the Beefheart off you ilo and put on the Monkey's and the remixes. Despite your wierd taste in music, it should do all this for you.
Think of your ilo as just a player and the WMP as the program that takes the music on and off the ilo.
Jan 17, 2008 | iLO (2 GB) MP3 Player
ILO does not list all songs.
switch to mtp mode or auto, and make sure the songs are in the correct format
Nov 05, 2007 | iLO (2 GB) MP3 Player
Fatal error
The hold/lock is engaged
Oct 05, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player
For my Ilo I can see the Ilo just like another drive when it is connected to the USB port. I can move files to/from the ILO just like any other drive. Similarly I can delete the files just like any other drive (for example using Windows Explorer).
Aug 08, 2007 | iLO (2 GB) MP3 Player
Computer locks up everytime I connect my USB cable into the MP3 ilo 2GB player.
Take it back to WalMart and get another one. This is broken.
Jun 26, 2007 | iLO (2 GB) MP3 Player
Incorrect Format Please Reformat the Player
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
Nov 28, 2006 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
60 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Rick
Rick
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
