Question about Hitachi 32HDL52 32 in. LCD Television
Hitachi lcd television model 32LD6600A
Tv screen has gone all fluorescent green, sound and picture not distorted, but impossible to watch.Recently took tv to an engineer problem did not arrive, brought it home within half an hour, green again sending us mad.
  • 11 Answers
SOURCE: hitachi 50v500a high definition tv
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
Posted on Aug 31, 2008
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
SD Tech
  • 14553 Answers
SOURCE: There is a red spot and distortion in the middle
I do not have good news for you---this model is prone to the optical light engine going bad---usually a red oval area in the middle of the screen----I have also read that there are now several class action lawsuits related to this problem in this set. You can Google the model number and you will set what I am talking about.
I have replaced several light engines(called an optical engine) in this model--both the 50V500 and the 60V500 have this problem.
The last time I checked the optical engine wholesaled for about 600 dollars and is major labor to replace--I had someone else here ask me about this set---He was in Canada and the first time he called Hitachi he was told they were not aware of any problem--after posting here with me he called them back and someone admitted they knew about this but had been told not to say anything or admit any problem---thousands of these sets all have the same problem.
Clearly the set is not worth a 600 dollar part plus labor---considering the cost of new sets, but the only other option you have is to try to connect with one of the several class action lawsuits---I found them by typing the model number and lawsuit after it on Google.
I know I am not giving you good news but I know this set.
If this information has been helpful for you, please take a minute to give me a vote here--I do this here for free.
If you have any questions or need advice reply to this post here.
Posted on Sep 11, 2009
SD Tech
  • 14553 Answers
SOURCE: My Hitachi lcd rear projection 50v500 television
There are already several class action lawsuits in several states concerning this problem in this model.
What happens is the lamp the set uses damages lens etc inside the light engine--the engines are now being sold on an exchange basis and are all rebuilt units---that are supposed to not have the same kind of problem as the early ones.
If this helps you, rate this solution as I do this here for FREE.
Posted on Nov 12, 2009
  • 171 Answers
SOURCE: my Hitachi Ultravision LCD rear projection 62
that is correct you need to replace the optical block to fix this problem the LCD chips are starting to burn out and the it why you are getting this problem reflecting on the screen this parts are around $230.00dlls to $340.00dlls plus the labor it is a thinker good luck I hope this was helpful
Posted on Aug 27, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a 50v500a Hitachi
THIS IS SO COMMON THERE ARE NOW SEVERAL CLASS ACTION LAWSUITS OVER IT---I suggest you get involved---the replacement engines are all rebuilt and supposed to "not have the same trouble".
Let me know if I can be of assistance.
sd tech
Posted on Sep 05, 2010
0 characters
1 Points
White screen
"White screen" on Samsung LED TV - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from
? 4:42
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Flat Panel Televisions
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Flat Panel Televisions
Hitachi 42pd6800 black screen when turned on, got sound no picture
Is this a plasma or an LCD TV? If it's an LCD TV then I would check the backlight inverters. If it's a Plasma TV then The Sustain boards there are two sustain board.
You can get parts for this TV at
Feb 29, 2012 | Hitachi Flat Panel Televisions
Hitachi 32LD8D20UA LCD TV, No Picture, Sound and Backlight Working
Replace the TV, the new ones are cheaper than repairing this one.
Feb 22, 2012 | Flat Panel Televisions
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My hitachi 960 tv has a green screen
you should take the remote,press the menu the screen this you can set your screen.
Jan 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Poor picture with hdtv Hitachi 37HDL52 plasma
What EXACTLY is wrong with the picture? Is it black and white? Green? not there? distorted? need info...
Sep 20, 2007 | Flat Panel Televisions
Hitachi 32HDL52 32 in. LCD Television Logo
89 people viewed this question
Top Hitachi Flat Panel Televisions Experts
Are you a Hitachi Flat Panel Television Expert? Answer questions, earn points and help others
