Question about Lexmark JetPrinter Z55 InkJet
How can I add my Lexmark Z55 to my new windows xp?
I have plugged in the printer into my computer and it still says it cannot install, no detection. Please help.
  • 1,605 Answers
Unplug the printer from the computer. turn off the printer.
install the printer software on the computer. if you already install the software, then restart the computer.
turn on the printer and connected the printer to the computer.
Posted on Dec 02, 2008
Want to install printer
If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
By default, Windows XP and Vista already has the generic driver installed.
However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
Thank you and good luck!
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
Have lost disc for lexmark X125 can you help install this printer
To get your software go to:,6959,204816596_652569478_0_en,00.html
And download there your printer software
In Windows, how do I install my printer?
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Parallel port printers Windows 2000 and XP
  1. In Windows XP default view, from the Start menu, select Printers and Faxes, and then double-click Add Printer. In Windows XP Classic view, or in Windows 2000, from the Start menu, select Settings, then Printers, and then double-click Add Printer. This will start the Add Printer Wizard. Click Next.
  2. Select Local printer or Local printer attached to this computer. Click Next.
  3. Select the LPT port.
  4. Select the manufacturer and model for the printer you are installing. If you would rather use the driver disk that came with the printer, insert that disk and click Have Disk, and then browse to the driver disk and the proper folder. Click Open, then OK. Sometimes at this point, you will be asked if you print from MS-DOS programs. Most people can safely answer No here, but if you print from any DOS-based programs, answer Yes.
  5. Windows will offer a name for the printer that you may change if you like. If this is your only printer, or you wish to use this printer most of the time, select Yes to make this the default printer.
  6. You will be given the option to share this printer on the network. Unless you specifically want to do this, select Do not share this printer. Click Next.
  7. Make sure the printer is connected and turned on, and then answer Yes to print a test page. This will ensure that your printer is working. After the page has printed, click Finish. Your printer should be ready to use.
Oct 18, 2008 | Lexmark Office Equipment & Supplies
Add printer without a disk.
Windows should detect any new hardware plugged into the system and allow your to begin to install. Connect printer cable to your computer. Then plug printer to power and turn it on. Windows should detect the new hardware and let you install. If it finds your printer click on the pop-up box at the lower right corner of your monitor to begin install. If it cannot find the driver follow instructions below:
type in model (ie., hp psc1210v) of your printer in your browser search engine followed by the word 'driver'.you should be able to locate a place to download the driver. Install the driver, connect printer and turn the power on. windows should find new hardware and proceed to install.
Sep 21, 2008 | Lexmark Office Equipment & Supplies
Lexmark Z55
does an error message appear on the computer screen?
Jul 03, 2008 | Lexmark JetPrinter Z55 InkJet
I do not know what operating system you are using, But most including Windows Vista and Windows XP are plug and play. That means that they will detect and set up your printer automatically. If it does not do so, when you connect the printer, just go into control panel and select add new hardware.
In the unlikely event that you do need the printer driver, you can download it on this page online at
good luck!
Mar 25, 2008 | Lexmark X6170 All-In-One InkJet Printer
I need to download the driver software for my printer as i don't have the cd.
It appears that Lexmark dont offer a driver forthe Z55. Looks like mine's going in the bin then!!!
Feb 16, 2008 | Lexmark JetPrinter Z55 InkJet
Z55 printer working with Dell Inspiron 530s
I have LexmarkZ55 printer which I have been using for years then all of sudden it stated that printer is not communicating with the computer and somthing wrong with the cable. I bought new one it still not printing.
Feb 13, 2008 | Lexmark JetPrinter Z55 InkJet
Set up disk
here are some sites from which you can download and install the drivers
Feb 09, 2008 | Lexmark JetPrinter Z55 InkJet
Lexmark JetPrinter Z55 InkJet Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
