Question about DEI Python 1400XP Remote Start/Keyless Entry System
When i hit the start button on my remote the indicator shows up but the vehicle will not start. the lights will flash once..... then about ten sec later will flash once again before disengaging.
  • DrivinMeCrzy Jan 05, 2009
    When I press the remote to start the car, lights flash but car won't start. Remote itself seems to be wearing out. Have to press harder each time I try to lock and unlock the car. Sometimes I have to go through this several times before it works and lately have had to be standing right next to the car or right in front of it to unlock.
  • Dan May 11, 2010
    What type of vehicle is this?
    Problem Solver:
  • 13 Answers
I would sugest first that you check your users manual. You may have changed a setting with out knowing. if you cannot find your manual just go here http://www.directeddealers.com/manuals/og/python/G562P_07-05.pdf
it is in PDF format. If that is a no go your car may have a demobilizer and your bypass module may have become defctive or not installed properly. hope this helps.
Posted on Dec 04, 2008
I have problem with remote control, my remote control gives me blue light to switch the dashboard on but there is no lights coming on the dashboard. what is the problem
Hi, your remote has probably lost its coding. If you have the owners manual check page 65 learning additional remotes. If not do the following 1. Plug in the 6 pin hopped coded plug to control unit under drivers seat. 2. Press unlock button twice to disarm. 3. Press learn button on hopped coded plug. this erases all pre learnt codes. The led on dash should start blinking once per sec. 4. Press learn button on hopped coded plug again. The led on dash remains on for 4 sec. and then starts blinking faster. Ensure to do step 5 within 25 sec. 5. Press any button thrice on your remote that has a problem. 6. In response led on dash remains on for 4 sec and then blinks once per sec.This indicates that the remote has been learnt. Hope this helps.
Mar 09, 2015 | 2006 Tata Indica LSi
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
I have a 2007 chevy tahoe with factory installed auto start. what buttons on remote or what sequence do i push to get truck running?There is a lock button an unlock button a rear glass open button and a...
To get your truck running with auto start first press the lock button and then hold down the semi cicle button for about 3-5 seconds this will start your truck
Jan 28, 2011 | 2007 Chevrolet Tahoe
My factory remote starter won't work, when button on key fob is pushed the parking lights flash like they're suppose to but the engine doesn't start.
Make sure to hit the lock button twice then hold the start button until starting. There can be several issues for a malfunction.If this does not work we can definitely look into other options but the biggest reason for an factory remote start not functioning is the check engine light being on.It completely disables the remote start function. Here is a list of possibilties of why the remote start will not function.
A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
• The vehicle is in valet mode. • More than 2 remote starts have been attempted. • The hazard switch is in the ON position. • A current hazard switch DTC is set. • The vehicle hood is ajar. • A current hood ajar DTC is set. • The CTD system detects an alarm trigger. • Excessive engine RPM • Excessive coolant temperature • Accelerator pedal position greater than 0 percent • Vehicle not in park • Vehicle theft deterrent malfunction • A current automatic transmission shift lock control system DRC is set. • A vehicle speed sensor signal is detected by the ECM.
Dec 16, 2010 | 2006 Chevrolet HHR
How do I setup the homelink feature in my 2000 chevy impala with my garage opener?
First clear it pushing the 2 outer buttons for about 20 seconds till the lite blinks.
Then here is the weird part take the old remote that you use for your garage door opener and hold it next to the home link in the car.
Push the button on your old remote then the button on the home link. the home link will flash slow then quickly (about 10 sec).
Now go push the learn button on the main door unit then back to the car and push the home link again for 2 seconds.
Oct 22, 2009 | Chevrolet Impala Cars & Trucks
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Oct 09, 2009 | 5900 SST 2-Way Security System / Remote...
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
Dec 16, 2008 | 2-Way Remote Starter
DEI Python 1400XP Remote Start/Keyless Entry System Logo
235 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
