Question about HP Office Equipment & Supplies
I had my cartirrage re-filled (BLACK) but nothing happens when I put it in no test page comes out and only color ink works even the cartirrage has been filled. HP PhotosmartC4280
SOURCE: HP Photosmart all in one C3180
My suggestion: Don't buy HP. I have the same region coding problem. All I want to do is buy HP ink, put it in my HP printer and print stuff. Too hard. I've wasted 30 pounds on ink and another 30 pounds on "support" phone calls to HP. Hopeless. I will never buy HP again. Waste of time and money.
Posted on Nov 19, 2007
  • 26 Answers
SOURCE: ink light on
you must verify all lefvels of yopur ink cartrages some of the others maybe low
Posted on Mar 08, 2008
proton77
  • 1183 Answers
SOURCE: Dell 924 printer problem with black cartridge
Dell printers donnot seem to work on refilled cartridges. Do buy new cartridges to fix the issue
Posted on Apr 15, 2008
pagebor
  • 2785 Answers
SOURCE: installed new color and black
plz clean the cartridge contact point and printer head contact point
Posted on Jul 01, 2008
  • 68 Answers
SOURCE: Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
Posted on May 28, 2009
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
How to refill hp photosmart C4280 psc all in one ink cartridges?
hi
check here for color one
for black
and for black XL
if i help you pls vote for me
Oct 03, 2010 | Computers & Internet
Brother MFC 5860cn magenta color is not printing. I printed the test page and did cleaning on it but the magenta color is not showing on the test page. The only colors showing are Black, Yellow, Cayan.
This can happen if the ink dries out for a long time. Try to power flush the color that doesn't work.
Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
press 7 then 6 then 4 then start black copy. This will fill the tubes with ink.
press 7 then 6 then 3 then start black copy. You may use the right arrow to choose the color you want to flush before you press the black copy button.
Press 99 to exit maintenance mode
Press the ink button and do a test print for print quality and see if the color you flushed works. If not, try again.
This is the only way to fix the dried print head. Otherwise you have to replace the print head, in which case, you might as well buy a new printer.
Aug 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
My HP Photosmart 8250 is not printing any black ink even when the cartridge is full.
If this is happening after the cartridge was just replaced then make sure you do not have any flags setup in the color settings page in printer preferences that is not letting it use the black ink cartridge. eg. gray scale using color only etc.
Try the Clean cartridge function in the service menu in printer preferences and see if the test page comes ok.
Dec 19, 2009 | HP Photosmart 8250 InkJet Printer
I just put in a brand new black ink cartridge, but the black ink will not print. It acts like it is, but nothing comes out.??? The color ink works fine.
Please follow the instructions given below ton print a test page and check if black color prints. If not then clean and reseat the black cartridge. If issue persists then contact HP Support to replace problem cartridge if it is in warranty and not a refilled cartridge.
  1. Press and hold the Power button, and then open and close the top cover four times.
  2. Release the Power button.
Oct 12, 2009 | HP DeskJet 3650 InkJet Printer
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Copier feature (Black or Color) only produces a Black page
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
May 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer will not print in color
I have put in brand new color and black and white cartridges. The black works fine on the test pages, but not one bit of color shows. How can I fix it?
Apr 18, 2008 | Dell Inkjet 720 Printer
19 people viewed this question
Ben Johnson
