Question about RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux Input Adapter
HOW DO I INSTALL A RCA ADAPTER TO MY VEHICLE
I GOT A STOCK 2005 NISSAN ALTIMA . IM TRYING TO INSTALL A 12 INCH SPEAKER AND AMP PROBLEM IS THE BACK OF THE CD PLAYER DOES NOT HAVE RCA"S SO I BOUGHT AN ADAPTER HOW DO I INSTALL IT
  • 102 Answers
There should be a diagram entitled "adding and amplifier to a factory stereo" in the owner/install manual of the high to low convertor. You need to signal tap some audio signal from your front or rear stock speakers in the car and those wires need hook up to the high to low convertor's input side. From the convertor you connect RCAs that go to your amp. In other words find your rear speaker wires and hook them to your adapter then hook up the rca wires
Posted on Dec 03, 2008
I have an 04 Nissan Altima I want to keep the stock radio but want to hook up an amp to it. There are no RCA hook up on the back of the radio. Please help, how can I do this?
You need a high/low converter. The converter will connect to two speaker wires and, covert that high signal to a low signal to run the amp. The converter will have RCA outputs for the amp. You will also need an amp turn on wire. The accessory wire (switched 12 volts) from the radio will serve this purpose.
Since you are already behind the radio; the accessory wire you need is purple in color. Left front speaker (+) is blue/white,(-) is blue/red. Right front speaker (+) is white/black, (-) is blue/black. You can use the signal from these two wires for the amp.
Sep 15, 2012 | Cars & Trucks
I have a 2005 Altima 2.5 94k miles and service engine light stays on. Trouble code stated that vss needs replacing. Where is it located. The car dies at any speed. help.
It is a vehicle speed sensor.It will cause many various problems other than your issue but definitely is what is causing yours.I am not familiar with all makes and models so I am including a link to assist you.The link is actually a google search page which I set up for you and includes locations and images.The first couple actually are links back to this site,but the others will be much more helpful.Good luck,Greg There is also a Nissan forum,but relates more to an ABS problem someone posted,although ABS could also be affected.
http://www.google.com/search?sourceid=navclient&aq=0&oq=vss&ie=UTF-8&rlz=1T4GGLL_enUS352US353&q=vss#sclient=psy&hl=en&rlz=1T4GGLL_enUS352US353&q=vehicle+speed+sensor+on+a+nissan+altima+2005&aq=&aqi=&aql=&oq=vehicle+speed+sensor+on+a+nissan+altima+2005&pbx=1&fp=10ed5043a6013aa8
Feb 14, 2011 | 2005 Nissan Altima
How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
  1. Remove or disconnect the following:
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
  1. Install or connect the following:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Apr 05, 2010 | 1999 Nissan Altima
How do i install a dual xinbp-210 car subwoofer with a pyle amp and stock stereo in a 2005 nissan altima
you can buy an adapter that splices into your back speakers and converts for your amp.
Oct 26, 2009 | Dual XINBP-210 Car Subwoofer
How do i install an interfire IB2400c amp?
Hello blown1914,
That appears to be a good amp and should power your subs with no problem.
You will want to install a line-level converter to your stock speaker outputs and use RCA cables to the amp. Here's a link to SonicElectronix line-level converters. The PAC SNI-35 is OK if your stock radio has a remote turn-on lead. If not, you should probably look at the PAC TRUNK-LOC. It still a 2-channel line output converter but also includes a trigger output to power on your amp.
http://www.sonicelectronix.com/cat_i331_line-out-converters.html
I tried Interfire's web site to see if they have a downloadable manual for your IB2400c amp. I could not find it, so it may be that it is no longer in print or no longer available.
You may want to go to their support page (link attached) and send them an email.
http://www.interfireaudio.com/contact.html
Hope this helps.
Apr 12, 2009 | Car Audio & Video
Subs not as loud as they should be plz help
RCA output level and speaker level output have different voltages and currents. The problem you are describing is common to folks trying to connect an OEM dash unit to an aftermarket amp. If your amp has speaker level inputs, try wiring to those......best bet..buy a new head unit, it'll sound better...louder and cleaner.
Mar 11, 2009 | Kicker IX404 Car Audio Amplifier
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Replace 2005 Nissan altima stereo receiver
Try radio shack, or stereo sales/installation place for ready to go plug adapter. For a few bucks, it saves headaches, and butchering the wiring in case you want to re-install old one later when trading in or selling the car.
Aug 30, 2008 | 2005 Nissan Altima
Do i need compassitor i have stock radio with brand new subs with XL2 1600 amp
This commonly happens when the ohm load is too low. Double-check the wiring to confirm that the speakers are wired properly.
Nov 19, 2007 | SPL Dynamics XL2-1600 Car Audio Amplifier
RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux Input Adapter Logo
1,637 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
