Question about GE Profile JTP56 Electric Double Oven
My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
  • 3,230 Answers
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Best of luck!!
Thanks
Posted on Jul 28, 2009
Ge profile convection oven giving error code F7. What parts do I need
Hi
Thanks for using FixYa. Error F7 means that the function pad button is stuck or the clock has gone bad. If you are unable to unstick the button then to resolve this issue you’ll have to replace the electronic range control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | GE Profile JTP18 Electric Single Oven
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
Oven flashing F7 serial number is jgrp17bew288
F7 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 10, 2010 | GE Profile JT910SASS Electric Single Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
I have a GE Profile JTP18. F7 is shown on the
Hi. this F-7 code is referring to a Shorted Clear/Off Key due to membrane switch, control or connector. unfortunately, this is an integrated control assembly and, the entire control board must be replaced in this case.
Replacing the control(ERC,EOC) will fix this issue.
Jun 16, 2009 | GE Profile JTP18 Electric Single Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
268 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
