Question about Maytag Refrigerators
I have just bought a brand new Maytag american fridge freezer but when my plumber fitted it he noticed the door on the freezer side doesnt shut properly and there is a gap all around the door. I contacted Maytags customer services dept as the product was only 10 days old they say that they cannot offer a replacement as all faults have to be reported within 7 days. Their only offer was to send a service engineer out to my appliance. The engineer came last week and didnt know how to take the door off and confessed he had never worked on this model before and so he ended up ringing for technical advice. He told me it would need a spare part ordering and told me they would contact me as soon as the part came into stock etc and arrange another visit. As christmas is coming and I need a freezer I rang today to find out exactly when this part would be fitted and was told it would be 6 - 8 weeks as it has got to be specially made at the factory!!!!! I am appalled that I have got to accept this service and solution on a brand new £1500 product that has never been used. Surely this is not acceptable? Can you advise me please? By the way I live in the UK so it is Maytag UK I have been dealing with. Thanks Sue
    President:
  • 1,462 Answers
Under sale of goods act, appliance has to be fit for the purpose. exchange of a faulty new appliance is not automatic but repair has to be carried out within a reasonable time and the normal ruling of a reasonable time is 1 month.
demand a replacement from the retailer. if no joy, it is very easy to issue a writ under the small claims proceedure - you don't need a lawyer for this.
go for it
Posted on Dec 03, 2008
Samsung Fridge Freezer Door Handle Came Off - No screws is it vacuum based.
The screws are in the holes on the side. You will need an Allen wrench to tighten them
Sep 29, 2015 | Samsung RSA1SHPN American Platinum Inox...
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
Jul 16, 2012 | Maytag Refrigerators
The fridge door will not stay shut. It is noticeably lower than the freezer-side door. We think there may have been too many condiments in the door pulling it down. Also, on the freezer door, there is a...
ON THE REFRIG DOOR LOWER HINGE, CHECK THE CONDITION OF THE CAM UPPER AND LOWER HALVES. ALSO YOU SHOULDN'T SEE ANY BLACK MAGNET ON A DOOR SEAL UNLESS IT'S BAD.
Oct 04, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag american side by side fridge freezer need to remove doors.
1st turn the water to thefrige. then disconnect the water line (front left bottom) then remove the caps from the top then remove the three screws on each side holding the hinges. with the door slightly opened lift straight up. then do the other side
Dec 08, 2009 | Washing Machines
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Refrigerators Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
