When I set My LG PC monitor to High resolution setting from 16 bit to 32 bit, its not supporting that resolution and start blinking only. I am unable to find , how to reset it to default.
  • 104 Answers
Restart your PC and press F8 before windows bootup and select VGA Mode so that when your windows finish loading windows in a VGA mode you can easily choose the Display setting you like. Remember to keep your Screen refresh rate not so high which can permanently damage your monitor.
Posted on Dec 02, 2008
  • Vanbiak Thanga
    Vanbiak Thanga Dec 04, 2008
    Normally you can use the resolution of 1024x768 with the refresh rate of 75Mhz
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
I get an error message regarding monitor resolution settings
It wants you to set your PC video resolution to the native resolution of this monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 27, 2011 | Princeton Digital VL173 Monitor
I have an Acer Aspire one and it won't let me change my resolution off of 800x600 I have windows 7 ultimate x64 (32-bit right?) i need help to get my 1024x600 res back.
Generally - you simply need to right-click anywhere on the desktop that does not have an icon present, and select "Screen resolution". Adjust the slider as needed to obtain the desired resolution. If the resolution desired is not available, choose another that is close.
Digging deeper, you might want to investigate the "Advanced settings" to make sure that you've got the correct drivers loaded in the settings for both the "Adapter" and "Monitor" tabs.
Lastly, "Windows Ultimate x64" is the 64 bit version of Windows. The 32-bit version is referred to as "Windows Ultimate x86" If there are both 32-bit and 64-bit drivers available for your Aspire, make sure you get the correct version 32-bit = x86 and 64-bit = x64. The "x86" tag came from the Intel processor line up where the "x" represented the generation (8, 16 and 32 bit CPUs) and the "86" were the last two digits to indicate the instruction set used by the CPU like this:
8086, 80286, 80386, 80486, etc.
The 64 bit CPUs are not x86 family processors, so they do not carry the x86 tag. Please rate this reply if it was helpful to you - good luck!
Jul 02, 2010 | Dell OptiPlex GX260 PC Desktop
Hi, my problem is that i can run my pc only in safe mode and if i try to use it in the normal way the monitor tunrs black and the blue light starts blinking, i can't configure it with the resolution...
This usually happens when your computer is set to a resolution that the monitor does not support. I have seen it when I set the resolution too high. That's why windows asks you to confirm the new mode after is switches to a new mode.
I think that in safe mode, you can set your 'normal' resolution. Try setting it to 1024x768 or something. If this helps you can try to find a resolution that works for your monitor. If -after a resolution change- your monitor goes dark: Don't touch the keyboard. Windows should switch back after about 10 seconds.
Jan 02, 2010 | Samsung 2333SW 23" Widescreen DVI LCD...
Fpd1975w display flashes on and off
what resolution are you setting your screen to? if you are setting it too high or to a resolution/frequency that your monitor doesn't support, it will do this. Try setting it to 800 x 600 w/ 32 bit color and a frequency of 60Hz. If you do this and the monitor still blinks, you may just have a bad DVI cable.
Jul 13, 2009 | Gateway FPD1975W 19" LCD Monitor
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
