Question about RCA Televison & Video
Cooling fan going bad hd50lpw42 - RCA Televison & Video
  • 586 Answers
    Cooling fan is just to maintain the temprature.It start malfunctioning with the durt.Therefore,First try to blower the mani PBC as well as fan.And if the fan not working properly the deattach it from PCB and clean it.And it will start work again fine.
Thanks for using fixya.
Posted on Dec 02, 2008
  • 4,472 Answers
Replace it with one of the same dimensions. Should be fairly easy. If you are not up to the task I highly highly recommend a professional as it should be a fairly easy job for any professional. If you need further assistance or help locating a professional please let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
    Sergeant:
  • 217 Answers
Check out first the motor of fan.and does any component getting heated u can notice.
RCA HD50LPW42 dlp, does not turn on
If capacitors are swollen,vented or puffed up on top replace them .You may just need to replace your Lamp.CK all fans make sure they are running. Mats Electronics has Best Price for Lamps 1-800-628-1118
Let me know if you need more help.
Mar 23, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
RCA 61" TV (HD61LPW165) Lamp Fan making noise
Here ya go:
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=662661
Much better longer life part. 80x80x25 mm 35 cfm with rotor lock wire. Connect the yellow to the blue wire on the tv, black to black red to red.
Sep 25, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Fans not working right
MOST OF THE TIME IF THE COOLING FAN FAILS TO OPERATE.THE COOLING FAN RELAY OR FUSE IS BAD.ALSO THE COOLANT TEMPERATURE SENSOR IS OPEN.THE COOLANT FAN WONT TURN ON.TO HELP YOU PIN POINT YOUR PROBLEM.GET IT SCAN.IT WILL TELL YOU IF THE COOLING FAN CIRCUIT IS WORKING OR YOU HAVE A BAD COOLANT TEMPERATURE SENSOR.YOU NEED THESE TWO COMPONENTS TO GET YOUR COOLING FAN TO OPERATE AUTOMATIC AGAIN.
Sep 18, 2009 | 1990 Ford Taurus
HD50LPW42 making noise near lamp
colour wheel doesnot have bearing.but if its faulty it makes some gearing noise or click click noise.check out.
Jul 13, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
HD50lpw42 rear projection tv. Once tv is on for a while it shuts off. Suspected fan problems, I placed a floor fan behinde tv, a few min later tv comes back on. Could it just be the fan or could it be...
Make sure your filter screens are kept clear.
Protect Components from Overheating
• Don’t block ventilation holes on any of the components. Arrange the components so that air can circulate freely.
• Don’t stack components.
• If you place components in a stand, make sure you allow adequate ventilation.
• If you connect an audio receiver or amplifier, place it on the top shelf so the heated air from it won’t flow around
other components.
Hope this helps!. Otherwise in your owners manual, under troubleshooting it states:
TV turns off while playing
• Sleep Timer, Wake-up Timer, or Watch feature may have been activated. Go to page 45 or 69 for instructions.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• The sleep timer may be set.
• Unplug. Wait five minutes. Plug in again.
Hope this help you out.
Jun 30, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
I have a RCA HD50LPW42, Rear Projection tv and my bulb went out after two years is that a good amount of time for the bulb to last. also I want to know about the fan. Does the fan only come on when the tv...
2 years is normal, I`ve seen some fail in 12-15 months, fans run when cabinet interior is hot, they are controlled by temp sensors located inside the set, video-tek
Jun 04, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Need info on fan for RCA HD50LPW42 TV
Thats a DLP and those fans are noisy. Most of those fans are special and I don't think I can recommend a dealer but you can Google Electronic Parts and pick one. They will need the Model Numbers as well as the Chassis number. There is no guarentee it will be any quiter for very long. You might check with some local TV shops and see if any of them have a good used one. DLP's go bad all the time and many times it's the light engine and the fans are realitively new.
Oct 14, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Really green picture with flashes
Hi...the flickering and the green is the colorwheel going bad. Very common for this model and an easy fix too.
Mar 28, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Buzzing
I have this same issue with mine as well. It is most likely the color wheel. Unfortunately I cannot find a replacement for it.
Dec 27, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
Televison & Video Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
