Microwave Ovens Logo
Stephen Hamende Posted on Oct 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a magic chef MCO165UB that the LCD display is black on and the oven won't operate at all. I've checked the fuse and it ohms out. I checked across the Bottom T.C.O. and don't get con
acmservice
Level 2:
Sergeant:
  • Microwave Ovens Expert 270 Answers
  • Posted on Oct 26, 2017
acmservice
Level 2:
Sergeant:
Answers
270
Questions
0
Helped
85502
Points
627
Sometimes that is a fan switch to turn on the blower if it gets too hot when cooking on the stove top. But you say the schematic shows it should be closed. So jump it and try the unit. if it works OK then replace it.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 19, 2008
SOURCE: Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
geemarie
Gayle Ashbach
  • 876 Answers
  • Posted on Aug 01, 2008
SOURCE: magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 27, 2008
SOURCE: Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Anonymous
  • Posted on Mar 02, 2009
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Anonymous
  • 3 Answers
  • Posted on Mar 18, 2009
SOURCE: Microwave oven blowing 20 amp ceramic fuse
Chances are if the varistor fails, it fails drastically causing a short circuit across the supply. It will sit across the supply (it will look like a thick ceramic capacitor) and you can check for continuity after isolating that at one end. If it shows low resistance (it should show almost open circuit with a Digital meter), replace it.
It need not be the culprit. If you are familiar working with High voltage circuits ( they are lethal inside a microwave ovens as the current capability is high here), you can discharge the doubler capacitor and isolate the high voltage diode to check for shorts in the HT area.
Magic Chef microwave model#mco165ub cant seem to turn up the power level. when I hit the power level button it cycles through -20, 0 and +20 but nothing happens when I hit enter.
Try unplugging the unit for a few minutes. The microprocessor on the control panel may have locked up. Leave it unplugged for at least 15 minutes to see if it will reset.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
2answers
My Magic Chef microwave oven blows fuse when i open door
If you're blowing fuses from opening the door that is the sign of a electrical short . You'll need to call a electrician to check it out. Changing the fuse in this unit can kill you. There's a capacitor that holds stored electrical energy that is dangerous. My good friend died from trying to change the fuse in his. Get a professional to check it.
Why is my MCO165UB display not illuminated?
Is the unit plugged in and is the light on inside when you open the door? If so you could have a blown fuse. The cabinet must be removed before you can replace the 20 amp fuse. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Magic chef not heating
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
1helpful
Microwave key pad won't work
That is a failed membrane keypad.
It is part number 3518522640B and you can order it from the Pros here.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus parts.
1helpful
Micro ios totally black . Had to reset the breaker ; is that a clue/
It has a fuse inside. Check the door switches while you're in there. The one in series with the fuse can weld in the "on" condition and blow the fuse and/or the circuit breaker.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
