Question about Linksys Computers & Internet
Can't secure my home network
Reset Linksys WRT330N. Ran setup from 192.168.1.1 Rebooted and receive message that says settings saved on the computer do not match the network. I am not sure what I am doing wrong. I used to have WAP2 but that option doesn't appear so I pick WEP. I put in a passphrase, I hit generate for random keys I go to administration and pick a password then I reboot and then I get the message.
    Genius:
  • 1,269 Answers
Hey, you're on the right track however, you'll just need to synchronize the settings on the computer. Follow the steps below.
1. Open the router's admin page (192.168.1.1)
2. Go to Wireless > Wireless Security
3. Security Mode: Select WPA-Personal
4. On the WPA-Shared Key or Passprase box, type your desired password. (Minimum of 8 characters.)
5. Take note of the password, click on Save Settings.
6. On your laptop, open Network and Sharing Center
7. Click on Manage Wireless Network.
8. Please remove all the listed networks
9. Click on Add > Add a Network in Range
10. Select your network and click connect.
11. Type the WPA password that you wrote down and connect.
You should all set.
Posted on Dec 02, 2008
I cant put safety as
Are you trying to secure the wireless network?
For this you will need to access the router setup page and change the settings manually.
See how to secure wireless network.
If you are not able to save the settings then I will suggest you to upgrade the firmware of your router. The reset the Linksys router and reconfigure it manually.
Create a new wireless network. Change the name of the wireless network that you never used before.
Then try to connect to the new wireless network.
See How to reset Linksys router.
See Linksys router setup
Jan 22, 2012 | Linksys Wireless-G WRT54G Router
Tip
How to reset your linkseys wireless router wep key.
Press start on your computer
click network
right click on the router
click on view device web page
leave user name blank
password - admin - ok
click wireless tab
change wireless(ssid) network name (anything will do, it will assign you the correct one) write the name down.
click reset security, wait till it fully uploads
click save settings
when the page reloads click on security mode - wep
enter 10 didgit code, letters and numbers: ie: abcde12345 (write down the number)
save settings
back to network on the start menu
setup connection or network
manually connect to wireless network
enter network name
enter security key
highlight the one you want
click connect
on Jan 31, 2010 | Linksys Wireless-G Broadband Router
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
Why can't I get my computer to connect to my linksys wireless? I keep getting a message that says "The settings saved on this computer for the network do not match the requirements of the...
Are you using a Linksys wireless router? It wasn't clear from your question.
Assuming you are, you'll need to reset the router to factory default, and then reconfigure it. Press the "Reset" button on the back of the router for at least ten seconds, then release. Then use your browser to go to 192.168.1.1 and use username "admin" and password "admin" to enter the setup pages. You can then reset your wireless password, etc. You'll have to re-enter the new logon information in Windows as well.
You should also set the router's access password to something secure, as it seems someone "got into it" while you were gone and played around.
Hope that's helpful.
Jan 16, 2011 | Computers & Internet
Lost my wireless connection on linksys wireless g wrt54g v.4 router help.... called linksys wants to charge 39.99 for a quick fix plz help
My friend,
Please reset the router by pressing the reset button for at least thirty seconds.
Open the setup page of the router with 192.168.1.1 from Internet Explorer.
Username=leave this blank.
Password=admin
Router setup page will be displayed then.
Click on the basic wireless settings .
Give the network name(your choice) and channel =6.
Under wireless security settings .
Click on the security mode should be WPA.
Put a security key.
Save settings.
It will start working wireless .
Saved your 39.99 $
Regards:-
Amit Awasthi
Dec 12, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys WRT120 connected to my home network. I have one computer "wired" directly to the router and one wirelessly connected with WPA2 security. Last week i was having connection issues with the...
I'd suggest that you reset the Router to its default factory settings. After doing so, when opening a browser, you should be prompted to initiate the setup wizard. Once set up I recommend checking for any recent firmware updates.
On the WRT120 the Reset button is located on the
right side of the product label. There are two
ways to reset the Router to its factory defaults.
a) Either press and hold the Reset button for
approximately five seconds.
b) Log into your router and restore the
defaults from the (Administration > Factory
Defaults) screen of the Router’s browser‑based
utility.
Check out the Linksys Support Page for your router.
I hope this helps!
Good luck and Please rate :)
Jul 30, 2010 | Linksys WRT120N Router
Our main PC works fine but, laptops cannot receive internet
1.Open the router page
2.Enter the Username and password(default password is admin and leave the username blank)
3.Click Wireless and fill the sections as mentioned
Wireless Network Mode-Mixed
Wireless Network Name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID broadcast-Enable and click save settings
4.Click Wireless security and select the Security mode as WEP
Encryption-64 bit 10hex digits
Key1-enter 10 digit or 10 letter password(like your 10 digit telephone number)
and click Save settings.
5.Click Advanced Wireless settings and fill the sections as mention
Beacon interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click save settings.
6.Click the link http://homesupport.cisco.com/en-us/wireless/linksys/
7.Enter the model number of the router
8.Click Download tab and enter the verison of your router (turn the router upside down to get the version)
9.Download the firmware file and save it on your desktop.
10. Click Administration on router setup page and then click Firmware upgrade
11.Select the file that you have saved on the desktop and start upgrade.
12.Turn off the router for 30 seconds after upgrade.
13.You can also delete the network name from your computer and add it again.
i hope this will resolve the issue.
Regards
Chiranjeet
May 23, 2010 | Linksys Wireless-G Broadband Router
I'm having a problem setting up my linksys wireless router. My computer sees the connection but will not connect to it? I've tried the repair option and tried to add a network with out any luck.
As i remember Linksys goes with Straight Through Ethernet cable. Always, good thing is to connect your computer to Wireless Router using LAN port. Set DHCP (Automatic) connection for your computer. After receiving ip from router you can setup your Wireless Router using GUI, and setup your Wireless Network, SSID/Security. From adapter to adapter there can be some misc problem with WEP/WPA/WPA2 and so on, so it maybe your issue, or OS blocking connection to Wireless Networks without security.
Apr 18, 2010 | Linksys Wireless-G Broadband Router
Cannot get a second computer on my secure wireless network
Have you set the properties on the second computer to match the security expected by the router? Since one computer works I would compare the settings for the network connection and set the second computer to the same.
Mar 15, 2009 | Linksys Wireless-G WRT54GS Router...
Set up required
You can use this software to re - setup your router. It is an automated setup that will you from the start. All you have to do is connect your computer directly to the modem and acees this link :
http://www.linksysfix.com/check/HomePage/index.htm
Just click on Easy Link Connect Link and save the file into the desktop. After Download just run the file or just double click on the file that you have downloaded.
The file icon looks like this :
Just Follow the directions in the interactive software setup. It will give all the instructions and will provide visual directions as well. For reference, here are the compatible models with the software :
BEFSR11
BEFSR41
BEFSR81
BEFW11S4
WRK54G
WRT100
WRT150N
WRT300N
WRT330N
WRT350N
WRT600N
WRT54G
WRT54GC
WRT54GL
WRT54GR
WRT54GS
WRT54GX
WRT54GX2
WRT54GX4
WRTSL54GS
** You can check the model of your router at the bottom part of the device itself, check the small sticker and check the model number.
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
186 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
