I have problem with touch pad, with LH click i cant open any icon
SOURCE: I have an Asus K60 Laptop.I can not figure out how
Did you try the FN key and F9...
That is what they say to disable your touchpad
You have a function key which is called Fn That key allows you to use the functions on the F series keys
So Fn then F9 should do the trick
Testimonial: "Awesome! THATNK YOU!"
SOURCE: Netbook Touchpad not working.
Apenas solucione este problema hace unos minutos,localiza en la esquina inferior derecha el icono que dice Dispositivo Señalador de Synaptics, clic derecho y seleccionas "Toque Rapido para Hacer Clic" y listo!!! si no te aparece el icono tienes que ir a Panel de Control, vas a Mouse, en la pestaña Configuracion de Dispositivo, seleccionas Icono de Bandeja Animado en la Barra de Tareas, ya con el icono en la barra de tareas haces clic derecho sobre este y seleccionas "Toque Rapido para Hacer Clic"
Espero haberte ayudado, bye
SOURCE: my asus eeepc touchpad doesnt work.when i press
Hello and Welcome to FixYa!
Please explain your query in a bit detail. How this happened. Did it started at its own or the unit is replaced/ physically damaged, ever since the problem started. And what exactly happens to the touch pad. Did it misses the instructions press, or did it start repeating one instruction for a certain time period.. A bit detailed explanation of the scenario would be helpful, for suggesting a precise solution to the problem.
Concerned.
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Click Start/Control Panel and
look for the Mouse and open it to check the mouse properties. Make sure
you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the
button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper
left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and
Hold the ALT or FN function key located at the lower left portion of the
keyboard, then hit the key that toggles the touchpad. The correct key to
hit will have the icon of a finger pointing at a square that represents the
touchpad.
Download and reinstall the touch pad drivers.
Get online and got to
www.google.com In the google search box type: "ASUS Support"
(without the quotes and put your manufacturer name before Support). Look
for downloads and drivers. Enter your model number and operating system when
requested. Download and install the Touchpad drivers.
