Question about Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G R Motherboard
Pc boots and stays on the black screen at the start
The pc boots ok dose the one beep thing (set up properly) then stays on the black screen that tells you the cpu -motherboard type and the shered memory then dose nothing but its still runing it jst boos and stays there mbGigabyte GA-MA74GM-S2H
cpu Phenom 8450 triple core C
ram 2Gb PC6400 800MHz DDR2 RAM x2 only one in coz it dosent pik up the tv with 2
  • explosive_st Dec 02, 2008
    the key board dosent seem to let me presss to goto boot menu xpress recover menu ect but the key boadr workk it has sata drives but the thing is i dnt have a sata drive so i hooked up the hard drive throught the sam one u hook the cd rom to
    dose this mean i need 2 sata drive for the pc to work?
I have same problem but I have Skystar 2 card on board when this happend.I do not know how to resolve problem.
Posted on Jul 03, 2009
    Master:
  • 474 Answers
Try getting into the BIOS and making sure that it is detecting the RAM and HDD and Processor. Typically this happens when theres no memory or a memory problem. If its the Hard drive it will say NTLDR missing or Hard Drive failure. When its blank.
Does the Hard drive fire up when its sitting there? Does it seem like it booting the Hard drive or does it just sit there.
Also, if you have an onboard Video and a video card, try using just the onboard video for now, sometimes the Video card can cause an issue if it doesnt have drivers and comes up blank.
Make sure the bios has the video set to PCI or AGP depending which you have intstall. Or Auto if it has it.
I have had two Gigabyte board and im using one now and have had similar issues that where caused by a ATI video card.
Good luck and let me know if you still need help.
Posted on Dec 02, 2008
  • Chris Busch
    Chris Busch Dec 02, 2008
    well, you have to set it to SATA if your using sata drives. You cant hook a SATA to the CD Drive unless its SATA as well. Your CD Drive is probably IDE. If you have a Hard Drive thats IDE, make sure the jumper on it is set to MASTER and then plug it into the master IDE ribbon or the one at the end and the cd drive jumper is set to Slave or cable select and put it on the second IDE connector.
    The jumper is the plastic conector that is on the metal pins next to where the ribbon plugs in. The case should have a diagram showing which jumper setting is for master and slave and Cable select.
    The thing is, even without a hard drive you should at least be able to get into the bios
Toshiba will not boot
It needs those things to start up. If you reinstalled them in the machine and it won't start up you need to check some things:
Does the screen flicker when you power it on or does it stay completely black? If it stays completely black, then the connection from the screen to the computer itself is lost. Normally it is caused by a broken cable.
If the screen flickers and then goes black, then check the following:
Does it beep at you? If it does, then the amount of beeps is important. It will state in the users manual what that numbers mean.
If it doesn't beep, then my best guess would be that there is something wrong with the power distribution in the machine.
Sep 07, 2014 | Computers & Internet
Black screen with white letters reading "REBOOT AND SELECT PROPER BOOT DEVICE"
Misty here is what I would do:
1.Start the computer in safe mode.
2. update drivers. I go into Slim Driver - a free prog. and scan the system to see if ok or need updates.
3. once updated, reboot the system normally - any change? GL
Feb 01, 2014 | Dell Inspiron M5030 Laptop
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
Black screen please help
the beeps are called BIOS BEEP codes. and is telling you what is wrong.
does run with no battery removed
do the BIOS screens work they MUST at all time. power on ,hotkeyed.
is the fan running
its old right,
like an old car that will not start do you buy a new car?
or buy a new battery? hummmmmmmm
ever heard of a tech>/? those folks that diagnosis things?
tried taking battery out, but failed to say it would not run only on the power pack. take it out and leave it out for now... be wise.
so the HP logo works every-time you never said that yes./no.??
thAT hp LOGO IS A BIOS LOGO FROM HP.
if yes the BIOS is ok. see? means the brain works the Ram is not dead and if you had pressed the BIOS hot key F1,F1, Esc, F10
what ever it is , it tells you what at boot in text. if you look there.
if it stalls with good bios that means.
bad HDD or bad OS.
SOME NEWER PC HAVE f10 OR F11 RESTORE KEY
IF YOU Press that, at power on ,it goes to restore mode.
(means reload windows)
oops HP retired this PC
https://support.hp.com/us-en/retired-products
that means in English clear, its NOT SUPPORTED NOW.
no books no software no updates no NUTTN
No anything, !
now you know why mom dump it.?
LOL !!!!
its a dead fish.
or FORD, found on road dead. LT.
why not report the beep codes
clear and accurately,??????????????????????
run the LT with no battery and level it like that till cured.
then, replace the COIN cell, no laptop this old has good 3vdc coin cell, impossible I bet.
if the cell dies, as all do in 5 -10 years.
the PC beeps with CMOS clock, NVRAM errors.
the battery size of a coin, runs the Real time clock and the
CMOS memory bank for the BIOS settings.
if the coin goes dead BIOS GOES NUTS ANT TIME/DATE goes NUTS.
if the beep codes say the HDD dont boot that usually means HDD is dead.
the trouble with beep codes are that there are many BIOS used
and many codes used. some are impossible to find.
beeps are now gone we flash LED codes now.
this is DT coin, LT is warped in plastic and 2 wires. see the COIN?
http://www.pcdied.com/coin-dt.JPG
beep?
1 long , 1 short, ? is COIN dead.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
note the black hole OF BIOS code HELL here, its a bad place to be.
for sure.
one other test is go to BIOS page.
see that time/date, year, settings. if way off the COIN is dead.
learn to that a 1/2 dead coin can work now, then file and 1 hour later work, that is how batteries fail. they go MARGINAL sometimes.
Apr 03, 2017 | Compaq Presario 1800T Notebook
Turn on Pc, Continually beeps 6 times then shuts down
it seems that your memory card is out of place. open the pc, reseat the memory, and that should be ok.
Jun 15, 2009 | Dell Dimension 3100 PC Desktop
I HAVE A DELL INSPIRON 1200 NOTEBOOK AND WHEN I WENT TO RESTART IT. IT WON'T START UP AFTER THE DELL PAGE IT BRINGS UP A BLACK SCREEN WITH A BLINKING WHITE LINE. I HIT F12 FOR BOOT MENU, IT DIDN'T WORK I...
ok well if that is all it dose then you are going to have to restore the computer back to factory settings and then try it but befor you do that have you tryed starting up in safe mode that might work.
please rate my help to you.
thank you.
Apr 21, 2009 | Dell Inspiron 1200 Notebook
Computer beeps and fails to start
If there was recent hardware added to it or RAM then try removing it and boot up. You can try resetting the RAM. You can also check all cables and power within the case to make sure everything is connected properly. Listen for the fan on the PC, if the fan doesn't start up then it could be an overheated mother board. Beeps can mean a number of different things. If there's no error on the screen then it probably isn't getting further then the BIOS. I hope that helps.
Apr 06, 2009 | HP Pavilion a1410y (RB042AV) PC Desktop
Gateway c140 beeps
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Mar 21, 2008 | Computers & Internet
Hp pavilion dx8210us notebook
Check the ram on board, reseat it and try again. Sounds like a memory problem to me.
Dec 21, 2007 | ASUS M2NPV-VM Motherboard
Blank screen after xp welcome screen no power to keyboard
Ok, with your current set up, what beeps are you getting? Also, while you have a blank desktop, hit CTRL+ALT+DELETE and you'll have Task Manager come up, click File and then New Task and type in "explorer" without quotes and hit enter. That should restore your desktop. Let me know how it goes.
Sep 07, 2007 | Asrock K7VT2 Motherboard
Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G R Motherboard Logo
359 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
