Question about Wolf Range fs-0-27-ft36 Gas Kitchen Range
Wolf Model R364G has a delayed ignition in the oven
Turn the oven on to any temp and when the oven turns on sometimes the oven door will blow open and then close. Wolf has a recall on this range But I'm not sure if the free in home fix applies to a second hand stove
  • 1 more comment
  • Anonymous Feb 12, 2009
    I have the same problem with my 30". This is actually the third one from
    Sub Zero disguised as a Wolf.
    My wife will not use the broiler due to the violent whoosh followed by the blue flame shooting out of the door. All 4 igniters fire at the same time if the oven is on when a burner is used.
    This is one exciting stove
  • Anonymous Mar 25, 2014
    when i light oven, there is a delay, then door blows open!
  • Anonymous Mar 29, 2014
    oven door won't close
    Habit-Forming:
  • 171 Answers
Yes it will applie to to second owner.
Posted on Dec 06, 2008
  • Michael Donovan
    Michael Donovan Feb 01, 2011
    Same problem with my R364G....still haven't heard back from the company but hopefully they get out here soon before I end up with a George Constanza head.
Need an owner manual for Wolf 6 burner Model CH-4-29-FT11
Try Googling (wolf)(CH-4-29-FT11)(manual) without parens.
Jun 11, 2017 | Kitchen Ranges
How do you turn it on and set temp
ELECTRIC RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/digitalassets/.../Use%20...
Whirlpool Home AppliancesPress the number keypads to set a temperature other than 350°F (175°C) in 5° ...Timed Cooking allows the oven to be set to turn on at a certain time of day, ...
Oven Temperature Issue ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../oven-temperature-not-same-as-set-t...
Sub?ZeroOvens will heat up higher than the oven temperature set point and then turn off. ... If oven temperature is off on an R or GR Series Gas Range, ensure that the ...
Oct 29, 2015 | Kitchen Ranges
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
Burners turn on sometimes as does the oven but then may not turn off
Hello, when you turn on one of the burner, can you hear some clicking while you turn on one of the burners? This is an electric ignitor, and when you turn one burner on all the burner ignitor will click.
It is possible, that you are turning your burners on the stove to quick. Take a look at one of knobs and you will see ignition--low---medium---high. To get the burning ignited the knob needs to be position at the ignition site. You'll hear it click-click-click and the burner will ignite.
Now, the oven. The oven ignitor is on a time delay. You will push the bake button and across the screen will say something like this "Please set oven temperature" You'll set the oven temperature to---let say 350 degrees---. Then the screen will say "push start button" then you push the start button to turn your oven on. Now, the screen will say "pre" this means that the oven is pre-heating the oven to your desired temperature. Before all this happens there is ignitor in the oven and it has a heater on the ignitor in oven. This heater will heat up to desired temperature and once it reaches the that temperature the ignitor will ignite and the gas will turn on.
Why--one would say for this procedure. The old kitchen stoves had a very bad habit of of flash over---that is gas will built up in the over and once the pilot light ignited the gas---wussh and it blow the oven door open. These ovens would sometimes huff too.
Therefore, take your time and your biscuit will be OK
I am sorry Sandan2. I didn't finish reading your question. Never mind on what I said here.
If the burners will not shut off sometimes, then there could a gas regulator problem.
One very important question. Is your kitchen stove using Natural Gas or LPG--liquid Petroleum Gas?
If it is using either type of fuel as mention above. It is very important that you contact Appliance repair person that is certified by the state that you live in that he/she is license by the state to work with gas appliances.
I wish you luck, but it very it important that you contact a certified Technician... Also, move the stove away from the wall and look behind it. There a black gas pipe and at the end is a brass valve, Take wrench and turn the gas valve off. The gas valve will have a stainless steel flex line attached to it, and the other end is to your stove. Don't use your stove.
If those gas burners and the oven are leaking gas. There is possibility to blow you and your family with your home up. Don't use the stove, Until you have it check out...please. GB you/your family...stewbison
Sep 07, 2011 | LG LRE30755ST Kitchen Range
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
No gas to oven
Hello, even though the igniter is glowing it does not mean it is drawing the correct amps to open the safety valve. If your igniter is glowing orange replace it. Igniters should glow brillient yellow to the point where you cant look at it. replace the igniter and you will be good to go. Good Luck!! Mike
Oct 01, 2009 | Wolf Range WKGD-2 Gas Double Oven
Igniter on Wolf Stove clicks continuosly
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
Wolf Range fs-0-27-ft36 Gas Kitchen Range Logo
1,233 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Dan Webster
Dan Webster
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
